Old 07-31-2023, 09:11 PM #1
lasfit's Avatar
lasfit lasfit is offline
official vendor
lasfit will become famous soon enough
official vendor
lasfit's Avatar
New Arrivials!!! 2023 New Generation LED Bulbs
Calling all truck owners!
Lasfit has just released brand new LAair series All-in-One Design LED bulb.
Apart from the mini size that is 1:1 with Halogen Bulbs we have also increased its light output to be more powerful. LAair Series
1:1 OEM Halogen Bulbs Design
1:1 OEM Halogen Bulbs Design means you can perfectly replace halogen bulbs without worrying about fitment issues or whether the dust cover can close, as they are designed to fit seamlessly with the OEM rubber dust cover and prevent any dust, water, or debris from entering the headlight housing.
Super Brightness with Clear Output Beam Pattern
Truly 35W, 3800LM, 6000K per Bulb with 12PCS LED chips present, the visual output can be enhanced, offering a brighter and wider lighting range. The lighting source is positioned in the same location as halogen bulbs and pairs flawlessly with projector or reflector headlights to produce a clear, well-defined light beam pattern with a sharp cut-off. It has consistently perfect beam patterns without glare.
Upgraded Cooling System with Built-in Temperature-Control System
The L-shaped exterior integrates a high-power fan and uses an upgraded heat dissipation system to ensure a longer service life. The 20mm cooling fan expels the heat efficiently, while the built-in temperature-control system ensures that the LED bulbs operate within optimal temperature limits.
So why wait? Space issues will no longer hinder you! Order now and experience the difference for yourself! LAair Series
New Arrivials!!! 2023 New Generation LED Bulbs-8-1000x571-1-jpg
Instagram | Facebook | www.lasfit.com | Youtube | forum.lasfit@gmail.com [909] 758 - 7900
lasfit is offline   Reply With QuoteReply With Quote
Old 07-31-2023, 09:14 PM #2
lasfit's Avatar
official vendor
official vendor
lasfit's Avatar
We now offer 5 sponsorship slots to experience our new products! Don't miss this opportunity, interested parties can contact us at forum.lasfit@gmail.com
p.s.The sponsorship is only applicable to users with a US address.
Old 08-01-2023, 02:05 AM #3
JoeBand's Avatar
JoeBand JoeBand is offline
JoeBand is on a distinguished road
JoeBand's Avatar
what year range do these replace?
2016 Silver TEP "Zilla"
JoeBand is offline   Reply With QuoteReply With Quote
Old 08-02-2023, 08:48 PM #4
lasfit's Avatar
official vendor
official vendor
lasfit's Avatar
These LED bulbs are used to replace OEM halogen bulbs.
May I ask the year of your 4Runner? I will recommend compatible LED bulbs for you.
Old 08-03-2023, 01:55 AM #5
JoeBand's Avatar
JoeBand's Avatar
Originally Posted by lasfit View Post
these led bulbs are used to replace oem halogen bulbs.
May i ask the year of your 4runner? I will recommend compatible led bulbs for you.
2016
Old 08-03-2023, 04:07 PM #6
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
The title is misleading since 2020-2023 have factory LED headlights
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
Old 08-08-2023, 06:18 AM #7
lasfit's Avatar
official vendor
official vendor
lasfit's Avatar
2016
The 2016 4Runner is compatible with the new LAair series LED bulbs.
LAair H11 LED bulbs fit your low beams, you can click here LAair H11 to check.
We also carry specific H11 LED kits with dust covers for 2014-2020 4Runner, you can click Pro-T4-H11 to check.
Old 08-08-2023, 06:19 AM #8
lasfit's Avatar
official vendor
official vendor
lasfit's Avatar
Thanks for your reminder. We tried to revise the title, it seems there is no place to edit the title.😂
Old 08-10-2023, 01:01 AM #9
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
FWIW, the factory LED headlights started with the 2021 model year.
02SE is offline   Reply With QuoteReply With Quote
bulbs , halogen , led , output , system
Best speculation of a 2023 6th generation I have seen peter78 6th gen T4Rs 1803 Today 01:00 PM
LED bulbs in front turn signals with incandescent bulbs in rear? Option01 3rd gen T4Rs 10 04-09-2023 11:32 AM
Second generation Tacoma CV axles vs 4th generation 4 runner CV axle mrwinkle13 4th Gen T4Rs 0 10-15-2015 06:02 AM
FS: TRS 9006: MORIMOTO ELITE HID SYSTEM (5000K bulbs) + 3000K bulbs $70 - Bham, AL momo.75 For Sale: T4R Items 8 09-18-2015 05:22 PM
H8/H11/H16 Philips X-treme Ultinon LED Bulbs Vs Halogen Fog Light Bulbs XenonDepot Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-22-2014 10:42 AM
