Old 08-16-2023, 09:04 AM #16
EC15. EC15. is offline
EC15. is on a distinguished road
Stuck calipers are possible. Happened to me.
You will still be able to stop but the pads wouldn't retract as mentioned.
Even if it's a year old, we don't know how the OP uses it. He could be driving through salt water on the beach every week.
I wouldn't ignore what the dealer said. Brakes are the most important system. Check it for yourself or have an independant shop do it.
EC15. is offline   Reply With QuoteReply With Quote
Old 08-16-2023, 03:59 PM #17
Milo99 Milo99 is offline
Milo99 is on a distinguished road
Brake drag
The bigger issue I have seen with brake calipers is not evenly clamping. The piston is well protected by a boot, so it moves, but the outer pad has to move on the sliding pins. If they seize, the inner pad pushes on the rotor but the outer one doesn't. This makes the inner pad wear faster. Sometimes you can wear completely through that pad while the outer pad looks fine. There are little boots on the pins that should keep them from getting corroded. Your new vehicle should go through a full set of pads before this is an issue. Sometimes when people replace brake pads they don't replace all the rubber pieces too and they Crack open from age. This is usually when it's a problem.
Milo99 is offline   Reply With QuoteReply With Quote
$200 , 15k , 20k , car , due
2022 TRD PRO - Nitto's vibration at highway speeds "HELP" Mark4runnar 5th gen T4Rs 25 11-03-2023 09:50 PM
2022 TRD PRO - "lime rush" Fort Myers FLORIDA Mark4runnar 5th gen T4Rs 7 01-26-2022 03:19 PM
Dealer Recommends Fuel Injection Service? alext72888 5th gen T4Rs 5 07-26-2018 04:14 PM
Dealer says, "SE had bigger brake rotors than SR5 or LIMITED" MICA4R 4th Gen T4Rs 22 03-06-2012 10:03 AM
" (!) " ...type "C" brake warning lamp...?! NYRunner 5th gen T4Rs 11 11-27-2010 05:18 AM
