Old 08-12-2023, 12:51 AM #16
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Yeah, some not very informed opinions here.
Just because a factory shock has not leaked after a lot of miles, or any other twin tube, it does not mean that it actually works properly. These shocks stop working well WITHOUT leaking. Not hard to figure out why factory shocks are usually of this design. It sure ain't for performance.
Monotubes are by contrast, "honest" shocks: they let you know immediately when they are done (due to the high pressure as mentioned above).
As for the Bilstein 6112, it is properly defined by Bilstein as an "adventure" shock. Paired with the standard springs (which are NOT 600 as vendors advertise them but less), they are NOT suitable to higher desert speeds. Ask me how I know. When you pair them with the stiffer springs, they work fine but it is a bit of a cheater performance setup because it is the springs that do the hard work. But it works.
Unlike the 5100, the 6112 can actually survive the punishment and with the stiffer springs, it is killer value.
Now, do you need 6112 on pavement? With the softer, standard springs, it is ideal for pavement and dirt roads. But you cannot expect it to last forever.
And the same is true of any other monotube, including the premium Dobinsons offering. It will leak eventually. I am pretty sure I can make the basic 5100s leak in a day or two, just in the desert around Phoenix. A 2.0 shock is ok for pavement, dirt, and rock crawling. But in the desert...been there, done that, too.
My 6112 are pushing 40,000 miles so I am not sure I will wait to 50k before I replace them, considering what mine have experienced. Nothing beats them at value, that's for sure.
The Dobinson setup is probably the other great value setup so no reason not to try that one either. But reservoirs would be crazy on a rig confined to a sad life on pavement
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 08-12-2023, 12:51 AM #17
cheeser cheeser is offline
cheeser is on a distinguished road
Originally Posted by mrblah View Post
bilstein will honor the warrantee, but there is a catch. You have to send in your busted shock and they will "rebuild it" and send it back to you.... so unless you have another shock lying around, your vehicle will be out of action for however long it takes for them to fix it. Also they don't pay for labor if you don't work on your own truck. So because of this downtime, the warrantee is absolutely useless.
As for kings and other aftermarket shocks, they only warrantee if for approximately 1 year, but at least when you have it rebuilt, it only takes a day at your neighborhood offroad shock to rebuild. The rebuild isn't expensive, its the labor that is.
there is no free lunch.
Thanks for the info on the Bilsteins…mirrors what the vendor has told me.
As for other rebuildable aftermarket shocks, trying to find a local shop to rebuild can be a pain, and still have to pay for the rebuild but cheaper than new.
Either way, still no free lunch as noted. Looks like I’ll just buy another set of fronts and send these out for warranty. I may wind up having a fresh set of fronts if/when we have to do this again in another 60k.
2023 SR5 Hefty FabWorks Sliders
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
cheeser is offline   Reply With QuoteReply With Quote
Old 08-12-2023, 01:01 AM #18
MAST4R's Avatar
MAST4R's Avatar
If you are doing anything more than the Alpine Loop and similar in CO, you may want to consider the 6112 on the stiffer springs. Yes, the ride on road will be stiffer, sportier, but the nose will actually stay above the rocks and not dive on them at the worst moment. Ditto for Moab.
Old 08-14-2023, 07:01 AM #19
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by cheeser View Post
As they’re advertised with a lifetime warranty, then that’s what I expect. If the lifetime warranty comes with the expectation of soccer mom conditions, then include that in their product marketing…I’m sure that would go over well.
Yea, I get that. But, keep in mind suspension is still a wear item that eventually goes out. Having a shock blow in the first year or two may justify a warranty claim, but 60k out of a set of performance shocks is a pretty normal service life, IMO. Bilstein may help you out with a rebuild as the other guy said, but I wouldn't expect anything more. If it were me, I'd just be ordering new shocks, probably Fox, and moving on.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 07:28 PM #20
After 5+ weeks, I heard nothing from Wheelers or Bilstein, so I contacted Wheeler again to check on the status of the warranty claim.
Bilstein has decided the seals are leaking through normal "wear and tear" for this mileage (actually 80k) and decided to deny any warranty claim...even they are supposed to be covered by a "Lifetime" warranty.
I fully understand shocks/struts wear out over time and need to be replaced or rebuilt, and a manufacture needs to protect themselves from individual claims for those times equipment has been abused. I'm not saying my installed struts should have lasted forever.
My issue is with Bilstein offering a "Lifetime" warranty by denying a claim for mileage when there is no stated mileage limit and the struts don't illustrate signs of abuse. They should simply state up front they only warranty them for x miles or a time limit.
Bilstein's claim of a "Lifetime" warranty is essentially worthless unless the shock/strut was broken/snapped where they would probably claim abuse and deny as well.
Off to purchase another set of struts...obviously not Bilstein.
Old 09-25-2023, 08:12 PM #21
Durango Dave's Avatar
Durango Dave Durango Dave is offline
Durango Dave is on a distinguished road
My twin brother and I had many '70s BMW 2002s including a nice 1973 BMW 2002tii that I had for 30+ years. So we put Billsteins with lifetime warranties on them and actually bought a whole extra set of shocks so we could put new ones on while we sent the old ones back for warranty replacement. At first they would just send you a new set of front or rears but eventually they started testing them and would send the old ones back if they determined they were still serviceable
2015 4Runner Trail Premium w/ KDSS and Moonroof
2023 4runner Off-Road Premium w/ KDSS and Moonroof
Durango Dave is offline   Reply With QuoteReply With Quote
Old 09-25-2023, 10:59 PM #22
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Dang.....
This is why we can't have nice thingsBilstein 6112s leaking after 60k miles - warranty?
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 06:57 AM #23
osugsxr osugsxr is offline
that sucks ...Curious about the fine print on the warranty. I've been happy with the TRD FJ kit 6112 & 5160 but replaced the leaking 5160s with 5100s . Once the 6112s start to leak or the spring breaks Ill probably go with a dobinsons set up. I have about 65-70k on the 6112s
Old 09-26-2023, 07:43 AM #24
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
I bought 6112’s about 6 years ago. When I was doing research on them before I purchased, I called Bilstein to ask a few questions. One of the questions was warranty, and they said these come with a 90 day or so warranty. Not the lifetime warranty as these are considered performance shocks.
I found the 6112’s to be too stiff and jarring. But they are a digressive shock. Progressive style shock is what I have now and rebuildable. Much happier!
2016 TEP
JPOVS is offline   Reply With QuoteReply With Quote
6112s , bilstein , i’m , warranty , wheelers
Are my 6112s leaking? joshik 4th Gen T4Rs 2 05-09-2021 08:05 PM
Front struts (6112s) are leaking, recommendations please Mo's TE 5th gen T4Rs 16 10-17-2018 05:15 AM
Will OME 885s fit over Bilstein 6112s 07V8 4th Gen T4Rs 6 02-22-2017 01:04 PM
Bilstein 6112s just to level it out - for now cheeser 5th gen T4Rs 6 11-24-2016 04:49 PM
Bilstein 6112s for $576 joshik 4th Gen T4Rs 2 04-12-2016 03:10 PM
