Old 08-11-2023, 08:31 PM #1
codyHTX's Avatar
codyHTX codyHTX is offline
codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light
codyHTX's Avatar
Horn Issue - Should there be a wire connected here?
Horn stopped working, tried swapping out for a pair of hella horns this afternoon but no luck, fuse 13 is still good so not that either.
could be the an issue on the steering wheel itself or somewhere along the wiring, but i noticed something that looked kinda odd
the factory wires look to go a short run to a connector just down/left of where the horns mount (pic 1&2). it looks like mine is missing the connector/wire that should clip up from the underside? (3rd pic where i pulled the connect and flipped upside-down)
can anyone confirm or verify for me that something should be connected to the other side of this? and if so where it comes from? I can't find a loose wire hanging around anywhere so a bit baffled.
thanks
Horn Issue - Should there be a wire connected here?-image2-jpg  Horn Issue - Should there be a wire connected here?-image1-jpg  Horn Issue - Should there be a wire connected here?-image0-jpg
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
codyHTX is offline   Reply With QuoteReply With Quote
Old 08-11-2023, 09:31 PM #2
BADCUDA1 BADCUDA1 is offline
BADCUDA1 is on a distinguished road
Looks like the mount tab for the temp sensor but thats a guess.
12 volts and ground = beep, beep.
Don't have that work your way back from there.
BADCUDA1 is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 01:56 PM #3
lazwa lazwa is offline
lazwa is on a distinguished road
I too am chasing an issue with my horn at the moment. My actual horn is working - tested by connecting direct to battery - but not when I press the horn pad on the steering wheel. The fuse also tested OK.
I'm beginning to think it's an issue with the K-Unit relay or wiring in between.
Are all of your steering controls working? Does the horn work intermittently at different steering angles?
Best of luck. Keep us updated if you find the problem.
2015 Trail Edition
lazwa is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 02:10 PM #4
Jeremy556's Avatar
Jeremy556's Avatar
Does the horn work when you crank the steering wheel left or right, how about with the alarm? Clock spring in the steering column is common failure
connected , horn , horns , issue , pic
Horn issue jscott6 4th Gen T4Rs 4 09-05-2020 04:04 PM
Bluetooth Issue - No Audio While Connected To USB blue$ 5th gen T4Rs 3 08-26-2017 11:06 AM
Horn is not working - common places for wire breaks? Ellis Precision 3rd gen T4Rs 2 04-21-2017 01:18 PM
Horn Issue 97roll Problems & Warranty Issues 0 05-19-2008 10:12 AM
speed/reverse wire, connected? chuey12 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-01-2005 02:29 PM
