Old 08-14-2023, 11:09 AM #1
mooch91 mooch91 is offline
mooch91 is on a distinguished road
Matte gray TRD wheels and LT load range C tires
Hi all,
Just picked up a set of the matte gray TRD wheels (the ones with the red TRD logo) in excellent shape to be installed on my 2014.
Can anyone tell me what models these were originally installed on, or if they were just dealer upgrades for any of the models? Also, has anyone identified a specific matching spray paint that is suitable for touching these up? Mostly the center caps which have some marks from an impact wrench.
I suppose I can ue my OEM TPMS from the SR5 wheels?
Also - I didn't realize these have LT load range C tires installed in the OEM size. Thought they were the P tires. General Grabber ATX, brand new. I reviewed the specs online, and there is about a 2 lb difference in weight between the LT and P tires (46.9 vs. 44.4 lb). Interestingly, a slightly lower load rating on the LT tires too (2470 vs. 2679 lb). Was surprised about this. They are not nearly as heavy as the load range E version (53 lb). Will I be disappointed in these tires for standard on-road use and some light off-road occasionally?
Thanks!
2002 Sport V6 210K - sold
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
mooch91 is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 01:00 PM #2
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about
thatoneguy's Avatar
Light offroad use? You'll probably be just fine. Lots of people on this forum offroad on P-metrics, we have a long running thread about it. For on-road they'll be much better than heavy stiff LT E's.
These tire load ranges get so weird. My P-metric Wildpeaks have a higher load rating than LT Load Range C KO2s, which have a LOWER load rating than the all-season P-metric tires 5th gens come on.
2023 TRD Offroad Premium, nautical blue
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 08-14-2023, 03:15 PM #3
Thanks. As mentioned, I was surprised that these LT-C tires had a lower load rating than the equivalent P.
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
Old 08-14-2023, 04:15 PM #4
Ripper238's Avatar
Ripper238's Avatar
Depends on how much air are in the tires, but its mainly because of the thicker side walls retaining heat on LT vs P. I also have LT-C load (Duratracs) and they have been great off road with the extra ply vs P load, plus they are lighter than E load.
I upgraded to those exact rims, love them but the red TRD center caps do fade so I may need to buy new center caps too.
Old 08-14-2023, 04:30 PM #5
Noticed that! Ceramic coat has brought back a little color, but I was thinking of looking for a new decal inlay and then re-coating with a matte clear.
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
Old 08-14-2023, 05:31 PM #6
Jeremy556's Avatar
Jeremy556's Avatar
When P metric tires are used on light truck and SUV applications, they are de-rated by, IIRC 9%. So your 2679 rated P tires are limited by the application to 2435 lbs.
Old 08-14-2023, 07:28 PM #7
thatoneguy's Avatar
thatoneguy's Avatar
Wow. I had never heard of this, but sure enough: https://www.tirerack.com/upgrade-gar...led-on-a-truck
I guess thatís another variable when I go comparing P metric and LT C offroad tires. Factory tires are 113 load index, things like the P metric Wildpeak are 115, and LT C KO2 is 112, but apparently the LT C KO2 isnít subject to the 10% load penalty.
At any rate, the vehicle from the factory is good for 113 load index Pís, and 115 is an improvement over that. I am curious what the P vs LT differences are that result in that 10% reduction in this application.
Old 08-23-2023, 01:12 PM #8
For those who may come across this thread looking for touch up information for the matte gray wheels, attached are the products I used with very good results on the center caps. Being matte, blending touch ups is fairly easy. I was able to sand and dust the impact gun contact areas on the caps with the graphite color, and a few coats of the matte clear really brought back the red in the TRD logo
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
installed , load , range , tires , wheels
TRD Pro Wheels - Matte Gray vs Gloss Gunmetal Gray lahori 5th gen T4Rs 8 05-10-2022 09:35 PM
Load Range C vs Load Range E rated tires BobsTrail 5th gen T4Rs 63 07-24-2020 12:10 PM
are there any load range C 275 tires? chrissurfr 5th gen T4Rs 3 09-05-2017 02:44 PM
Load range for tires krupnation 4th Gen T4Rs 27 11-19-2016 02:08 PM
Best load range for new tires? Bravo1 Engines / Suspension / Wheels / Tires / Audio / Accessories 12 06-08-2008 08:38 PM
