Old 08-15-2023, 01:35 PM #1
lj4r lj4r is offline
lj4r is on a distinguished road
Face lift on a 2010 4Runner SR5, high beam issue
I picked up a 2010 4Runner SR5. It had been stolen and used to run folks and pot through the desert. When I picked it up, it had lots of brush scratches and some from and rear bumper damage. I decided to do a 2014 and later facelift with new bumpers, front and rear. New headlights (2016 model head lights, fog lights, new 2016 model head unit and some other odds and ends. Also installed some Bilstein 5100s all around and some 2019 model wheels.
I decided to have it all repainted. It is finally almost finished and it looks like it is ready for SEMA. The paint work is stunning. It looks incredible.
I have a few items to dial in, including the center console lights not working (issue with the fuse box in the driver's footwell, maybe bad fuse that melted part of the fuse box). I noticed that the high beams work when used to flash, but when the steering wheel high and low lever is pushed forward to turn on the high beams, nothing happens. The other lights all seem to work as they should, low beams, blinkers, brake lights and fog lights.
Any ideas? My first thought was that it might be a high beam/low beam lever. Again, when the lever is used to flash the high beams, they work great.
Thanks in advance for any ideas.
LJ4R
EDIT: and just like that the high beams are working again. Not sure what was going on, but they work perfectly.
lj4r is offline   Reply With QuoteReply With Quote
Old 08-15-2023, 01:45 PM #2
Almost done, Final detail and wheels yet to be done
Face lift on a 2010 4Runner SR5, high beam issue-4runner-4-jpg  Face lift on a 2010 4Runner SR5, high beam issue-4runner-3-jpg  Face lift on a 2010 4Runner SR5, high beam issue-4runner-5-jpeg  Face lift on a 2010 4Runner SR5, high beam issue-4runner-2-jpeg  Face lift on a 2010 4Runner SR5, high beam issue-4runner-1-jpeg
Old 08-15-2023, 02:12 PM #3
Front before and new head unit.
Face lift on a 2010 4Runner SR5, high beam issue-4runner-9-jpeg  Face lift on a 2010 4Runner SR5, high beam issue-4runner-8-jpeg
Old 08-16-2023, 12:03 PM #4
One last glamor shot. Updated new takeoff wheels installed. I love the updated front end. Much more aggressive looking than the 2010 version. All in it was probably around $500 for the bumper ($200)and head lights ($100). I did have to buy a few new brackets, undercover and trim pieces. The 2016 head unit was around $150 as I recall. I needed a few harness pieces. Easy install. I have a short on the center console lights (radio, temp controls and gear shift lights). Blown fuse in the fuse box under the driver's side dash. Hopefully that will be sorted this weekend.
Face lift on a 2010 4Runner SR5, high beam issue-4runner-11-jpg
Old 08-17-2023, 12:54 PM #5
For those of you that are wondering what it takes to do a facelift on the 2010-2013 4Runner there is a great write up by Kevin Smith on Trail4R.com
5th Gen 4Runner Bumper Conversion, 2014+ Bumper Swap Install
There are also a couple of really good videos on Youtube.
Here is the parts list:
Parts List:
• Trail Bumper # 52119-35914
• Trail Valance, Silver # 53901-35240
• Trail Valance, Black # 53901-35250
• Valance Retainers x13 # 75392-35220, NAPA # 665-5135 (Same as Fog Light)
• SR5 Bumper # 52119-35912
• Bumper Reinforcement # 52021-35140
• Reinforcement Extension, Left # 52026-60050
• Reinforcement Extension, Right # 52025-60050
• Energy Absorber # 52611-35040
• Headlight Right # 81130-35541, TYC # 20-9511-00-1
• Headlight Left # 81170-35571, TYC # 20-9512-00-1
• OE projectors and light pattern are better than TYC
• Headlight Grommet x2 # 90189-05142
• Can use NAPA # 665-1050 (nylon nut) and # 665-2196 (screws)
Support Brackets
• Right # 52102-35100
• Left # 52103-35110
• Center # 52521-35060
Side Retainers
• Right # 52115-35151
• Left # 52116-35151
Fog Light Assembly
• Right # 81210-12230
• Left # 81220-12230
Fog Light Bezel
• Right # 52127-35100
• Left # 52128-35080
• Fog Light Retainers x2 # 75392-35220, NAPA # 665-5135 (Current chrome strip has a few)
Grille
• Upper Grill # 53101-35080?? (Can come painted in factory colors)
• Lower Grill # 53112-35060
PARTS YOU CAN MODIFY INSTEAD OF BUY (SEE BELOW FOR INSTRUCTIONS HOW):
Fender Liner
• Right # 53875-35150
• Left # 53876-35150
• 2 Wire Turn Socket # 90075-60028
• Or Dorman # 86424 (small spade terminals)
• Dorman # 02254 (3/4” bypass cap)
• Deflectors
• Right # 53293-35020
• Left # 53294-35020
You can save some $ on one piece bumpers without the valances and installing used parts. I found a front bumper and rear bumper for $200 each but ended up having to swap the rear for a valance-style bumper due to a broken counting tab. I also found used headlights and fog lights. Saved a ton not having to buy new from the dealer.
There aren't many newer style 4Runners around the San Diego wrecking yards so the pickings are limited.
Overall the 4Runner turned out great, drives well (the Blistein 5100s are a huge upgrade over the blown out Monroe quick struts) and is good for at least another 150,000 miles. I didn't keep an accurate count on the money I spent doing the make over. It was a fun project. Due to its history it is dubbed the "420."
Old 08-17-2023, 08:52 PM #6
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Parts List:
Support Brackets
Side Retainers
Fog Light Assembly
Fog Light Bezel
Grille
Fender Liner
• Deflectors
I also have a 2010 SR5. I like the light upgrade. Did those headlights match the hood, fender lines, and that grill trim piece like the originals? I gotta do this!
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 09:10 AM #7
it all fit together really well. Hood was not altered. Just the bumper and the top piece on bumper with the Toyota logo on it. The mounting brackets on each fender and the mounting brackets behind the bumper and grill. Overall, it was a pretty simple upgrade. Thanks to all of those that had done this before. Super happy with the results.
Old 08-18-2023, 09:28 AM #8
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
Very nice. I am about to do the 2014+ from the bumper swap on my 2012 SR5. I will post pics when done, just need the time to swap everything. As for the high beams not working. Sounds like the headlight master switch may be bad if the highs flah but won't stay on.
2012 SR5 4x4, Ironman 4x4 2.5" lift, Tuff Country upper control arms, pedal controller, DX4 Beast wheels, led ditch lights and brackets from Amazon, blacked out emblems, more to come. Previous Rig. 1997 SR5 4x4 no lockers, Trail Gear sliders, OME 881 890 lift and shocks, Magnaflow muffler, Airaid Jr intake, CBI ditch light brackets, Ebay led spot lights, 265/75R16 Mastercraft tires. 1996 Tacoma TRD Sport 4x4 2.7L MT bone stock on 32's.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 08-18-2023, 12:00 PM #9
Thank you. The head lights are now working perfectly. I have no idea what the glitch was, but they now work fine.
beams , high , lights , model , work
2005: Current HIR options for low beam (9006) & high beam (9005)? Iron Chef 4th Gen T4Rs 6 03-15-2021 09:07 AM
high beam indicator intermittent issue Slobo 3rd gen T4Rs 8 08-10-2018 02:08 PM
High Beam Issue johnsonnate 3rd gen T4Rs 12 02-21-2017 09:05 PM
HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors Cuco 3rd gen T4Rs 7 08-07-2016 11:17 PM
High beam issue Stuntmonkey 3rd gen T4Rs 17 04-28-2013 07:29 AM
