Originally Posted by batex
I just got back from taking my 2020 4R into the dealership for, among other things, a transmission fluid drain and fill. When reinstalling my RCI skid plates (I had taken them off, not just to make their job easier, but to ensure they were re-installed correctly), I noticed that the drain and check plugs appeared to not have been used/removed. There was no sign of those areas being wiped clean and am pretty sure there were no new washers on either plug. So, did my dealership actually perform a drain and fill? Do they have a another way of doing so that doesn’t use the drain and check plugs at the bottom of the transmission pan? Was the mechanic just so proficient he could do it without leaving any evidence? Or, did they possibly not do it?
Just curious….Thanks!
I would not let the dealer do a flush. It could ruin the tranny.
Do the proper drain and filter change.
I Told My Customer Not to do This, Now His Car is Destroyed - YouTube
If you feel that they might have cheated you (possibility) redo it yourself.
Assuring means nothing. That is why I only trust myself working on my cars..
talk is cheap....
