Old 08-24-2023, 07:05 PM #1
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
Part Identification (hard line)
I have what looks like a slow oil leak and it seems to be from this line, probably from corrosion, but I cannot identify it and haven't dove into the issue yet.
Looks and smells like engine oil. Drivers side frame rail 12" before the radiator.
2010 SR5
Thanks
ETA: Most of that juice in the pictures is Fluidfilm fwiw.
Part Identification (hard line)-img_4037-jpg  Part Identification (hard line)-img_4036-jpg
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 08-24-2023, 07:14 PM #2
Whippersnapper02's Avatar
Looks like transmission.
Old 08-25-2023, 10:16 AM #3
Humble Leader's Avatar
Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all Humble Leader is a name known to all
I think you have a power steering leak. it looks like that is the same spot mine ruptured almost 2 months ago but it might be a bit closer to the radiator than mine was - it's hard to tell with only those pics. that fluid would be transmission fluid which is used in the powersteering
Power steering line leak - what is this joint???
If it's the same leak I had then you need parts 4440660021 and 4441260430
Old 08-26-2023, 01:15 PM #4
Yes, that's exactly the same issue and part. Thank you very much!!!!
Old 08-27-2023, 09:37 AM #5
Ended up just cutting back the line and stretching the hose a bit. At some point I will buy some hard line and make a new section. No way I'm paying $100+ for this.
As a bonus, I flushed the PS fluid, which was needed.
Thanks again
Part Identification (hard line)-img_4041-jpg  Part Identification (hard line)-img_4044-jpg
engine , issue , line , oil , part
hard brake line part number help *pic* jeredcollins 3rd gen T4Rs 4 01-13-2020 01:30 PM
Hard brake line part # amajo75 3rd gen T4Rs 4 11-09-2019 02:16 PM
Hard brake line part number amajo75 4th Gen T4Rs 1 08-04-2019 09:55 PM
front brake hard line OEM part number or equivalent DK327 3rd gen T4Rs 22 04-29-2019 09:55 PM
Help: part number for brake hard line blackfc3s 4th Gen T4Rs 3 11-12-2017 03:34 PM
