Old 09-03-2023, 10:25 PM #31
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Was going back and forth on going with a stoptech or wilwood BBK. reached out to my parts contacts and had them verify if they were compatible with stock rotors since the sizes specified in the kits were stock rotor sizes. They said they were not compatible.
I really like the idea of having more rotor choices and since those are not 2-piece and the OEM rotors have many more choices I am sticking with OEM brake calipers.
With that said I will be doing a brake upgrade as I think that the stock brakes are just at their limit with ~600-700lbs static added weight combined with lots of mountain driving. I ordered the parts to revamp the brake system and hopefully it will feel better with knowing I can replace with OEM parts in a pinch.
parts list:
EBC Yellow pads
Stoptech slotted rotors
Stoptech stainless lines(I already have stainless 3rd member extended lines for my etxended travel rear)
Motul 5.1 fluid to do a full flush
Permatex extreme brake parts lube
Will make sure to bed the pads properly and hopefully they do better.
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 09-05-2023, 02:12 PM #32
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
I haven't had this problem yet anyway. But I agree engine braking is essential, on a long downhill never be in 5th gear, put it in 4th and lower the speed. Something else I always do is turn on the AC and turn on the headlights to provide a little bit more engine resistance from the alternator. I sometimes tow a pop-up trailer and I never had an issue with this strategy.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 01:27 PM #33
ILL.T4R ILL.T4R is offline
ILL.T4R is on a distinguished road
Same issue
Have you found a solution?
I’ve been having the same issue. Having had to replace multiple rotors and pads within the last year. Most recently set of EBC slotted brakes with yellow pads. These were done within the past month and I can already feel them warping. I do normal daily driving no harsh hills or sudden stops. Brakes and pads were bed in properly. I took it to Toyota and they say calipers/pistons are all fine moving freely no issues or sticking brakes. What is warping my rotors so frequently??? Anyone have any insight?
ILL.T4R is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 02:03 PM #34
EEEliminator EEEliminator is offline
EEEliminator is on a distinguished road
I had rotor warping issues especially when my 4Runner was my wife's daily . I switched to the dimpled/slotted rotors and pad from brakeperformance on the 4Runner and drilled/slotted on my wife's car and have not had any warping issues since. I had always used Toyota pads and rotors prior to that. I was hesitant to go with the drilled rotors due to fear of cracking but they warranty them against that. They've been on for a couple of years and no complaints other than they can be louder than the factory pads/rotors.
EEEliminator is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 02:09 PM #35
This is what I’m running right now (dimpled and slotted) less than a month in and I’m warping them again. Don’t know where to go next if Toyota and off road shops can’t find an issue. Don’t want to keep throwing money at in search of a fix.. but I might have to lol
Old 12-22-2023, 02:24 PM #36
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Are they warped though? What was runout measurement after install?
Any issue meeting specs?
Maximum disc runout: 0.05 mm (0.00197 in.)
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 04:48 PM #37
Toyota said they couldn’t measure runout due to the rotor being slotted, saying the slots would interfere with the measuring gauge. Me stating they’re warping is from the signs and symptoms of previous rotors that were in fact replaced due to warping. ie. vibrations when braking and front to rear wobble when coming to a stop. These symptoms get worse until I replace the pads and rotors once again. Going on my 5th set unfortunately.
Old 12-22-2023, 07:42 PM #38
CutthroatSlam CutthroatSlam is online now
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Ah but are you feeling pulse in the brake pedal? The wobble is more likely due to out of balance tires and wear on front end components. Been there and corrected that.
This is what happens when one simply throws parts at a problem without correctly diagnosing the cause of the problem.
CutthroatSlam is online now   Reply With QuoteReply With Quote
Old 12-22-2023, 07:54 PM #39
You know what.. I’ve never payed attention to it due to me focusing on the actual movement of the vehicle vs pedal. I’ll go drive a bit and report back. But yes you are 100% describing me. I have done multiple balances/road force balance. Replaced UCAs, inner/outer tie rod ends, Swaybar bushings, needle bearings to clamshell bushing. Almost every component with a bushing besides LCAs which look to be in good condition. Mainly due to shops not being able to find a problem and my hardheadedness in trying to find the perfect ride…
Old 12-23-2023, 09:54 AM #40
No noticeable brake pulse. Just the front to back swaying of the vehicle when coming to a stop. What beats me is that during the first couple months or so of me having new brakes that motion is not present at all. As time progresses it turns into more pronounced shaking when hitting the brakes at higher speeds with very apparent brake pulse.
Old 12-23-2023, 02:26 PM #41
We had substantial wobble under medium to hard braking from 70 mph down to 40 mph. Is there feathered wear on the outside edge of the front tires? If so, try rotating them. I just had this on the 2014 SR5 and rotating the tires eliminated it.
Then again I've had it happen periodically over the 343K miles on the vehicle. I've done the rotor replacement thing and have stopped doing that unless they are worn. It's mainly tire balancing followed by wear in front end parts. We also installed the ECGS bushing in the front transfer case and that helped. With front ends, it's typically the sum of a bunch of little things.
Old 12-24-2023, 12:46 PM #42
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
I didn't read all the replies, so I hope I'm not echoing here.
In my experiences with the T4R braking assembly, the calipers/pads are problematic in a couple ways:
The seals are prone to failure in areas of salt. This may or may not apply to you, but it's a thing (front and rear).
Heat kills seals. Duh
The pads that you buy these days, are not properly sized or shaped to fit these calipers properly. NONE of them.
Issues:
The pads are mass produced and the metal flange can be off or misshaped.
More importantly, the coatings they use end up leaving an oversized amount on on the contact area of the pad relating to the "slide" on the caliper.
Mitigation:
Sure, you can slam the pads in there. They will work. But over time they will willingly slide less and less till they inevitably stop returning and ride the caliper producing excessive heat, and the caliper will take a shit. $$$
I take some time and file down the pads where it contacts the caliper. I want them not so much loose, but free moving. When they heat up and expand, they will be slightly snug. Grease them appropriately.
Side note: I live in a winter salt hell. The only rotors and calipers I will use is Reybestos. The zinc (or whatever) coating they use holds up for a LONG time and they do not rust. The rotors last because I don't over heat them because the pads, and ultimately, calipers behave properly.
As far as downhill on long steep grades, people here have far more experience than I do. I'll defer
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 04:20 PM #43
Issues:
Mitigation:
Same here, I only use the top of the line Raybestos pads and rotors, and I do not live in a rust belt area.
As far as what to avoid, any rotor made in Pakistan:
https://www.instagram.com/reel/C1JVE...12dm1wdm4yaQ==
Old 01-26-2024, 09:04 PM #44
Follow up on wobble issue
After taking it to multiple Toyotas and two different off road shops. No one can figure out what my issue is. Even did another alignment, had all of the suspension/driveline checked, even had the master cylinder checked and calipers replaced out of getting desperate and nothing. Still wobbles when coming to a stop. Real close to giving in and selling. Only thing holding me back is these crazy rates.
issue , issues , oem , pads , rotors
Grinding on front brake rotor Ross302 3rd gen T4Rs 2 05-05-2017 02:37 PM
3rd gen front brake and rotor install | How to chipsahoy 3rd gen T4Rs 3 04-19-2017 04:57 PM
'00 2wd front brake rotor removal gearnuts 3rd gen T4Rs 4 02-27-2013 09:24 AM
Trying to Remove Brake Rotor, Having Issues 87 4Runner iminanalog Maintenance/Detailing 10 09-09-2012 04:10 PM
[2004 v6 sports] Front brake rotor and pad. rshin82 Problems & Warranty Issues 5 10-10-2010 11:29 PM
