Old 09-08-2023, 03:10 PM #31
CrawlCulture CrawlCulture is offline
CrawlCulture is on a distinguished road
Originally Posted by srsrogerissrs View Post
I think people are just driving broncos like you would a jeep. However, it's still an IFS so you can't just yeet an IFS everywhere. I'm sure the front locker doesn't help either (in regards to their steering failures). The only downside I see for the Bronco is how massive they are.
If you are talking about rock bouncers, those basically just have jeep bodies if they aren't fully buggy'd. Stock jeep components would not handle that abuse. I wheel with a lot of toyotas with IFS that are locked front and rear (a couple have dual cases) and the stock steering components have never been an issue for us. That being said, I always carry extra tie rods kinda like I carry CVs. The CVs are really the major "issue" with IFS but we will break solid axle axle shafts as well, it just isn't as common. Broncos have notoriously weak steering components (tie rods in particular) that is more than simply an IFS issue. It is a common upgrade on Broncos but you don't really see it in Toyotas as much until you start going long travel IFS and need extra length.
I personally took a hit on my front driver that trashed the CV and wheel bearing and seized the tie rod but the tie rod is still going strong. They do break, I've seen an FJ break both, but I wouldn't consider it an issue like it is in those broncos. If you are doing a trail like the rubicon, I'd take spare parts but I would not anticipate a tie rod breakage like I would a CV. If you are someone who does drive a 4runner and somehow breaks tie rods, I'd upgrade to a tundra rack/rods. Break it, upgrade it... thats pretty much the name of the game haha
CrawlCulture is offline   Reply With QuoteReply With Quote
Old 09-08-2023, 04:32 PM #32
AZ Craig AZ Craig is online now
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Originally Posted by Xtremluck View Post
Id be willing to bet good money that there have been more 6th gen Broncos that have done the Rubicon Trail than 5th Gen 4runners. I see them pop up in the Rubicon FB group I'm a part of. They do just fine but are subject to the same IFS steering breakage risk that our trucks have. Also as @srsrogerissrs mentioned the front locker certainly doesn't make things easy for those tie rods.
Completely true. Yes, the Bronco hasn't been the most reliable vehicle to date, but it's going to out perform the vast majority of 4Runner's, likely with less modification to it alone on the fact that it has better angles and a much easier ability to take 35 and 37 inch tires than a 4Runner ever does.
Don't get me wrong, the 4Runner is amazingly versatile and can get through terrain way nastier than most people would ever dream of bringing one in. That being said, it doesn't necessarily make it easy like some of these other vehicles rolling on huge tires quite frankly can.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is online now   Reply With QuoteReply With Quote
Old 09-08-2023, 08:10 PM #33
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Originally Posted by 02SE View Post
I'm assuming you're talking about the Broncos currently on sale, and not the little Bronco Sport CUV versions also currently on sale.
Considering the failures in the steering system I've seen them have on fairly easy obstacles, I'd say not well.
1973 Bronco w/ 302 and 3 spd manual transmission.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 09-08-2023, 09:06 PM #34
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
That depends on many factors.
Stock they had very small 7.00-15 tires. 2.34:1 low-range gearing (not really low, but decent for the time). Power was 137 hp, and 230 lb-ft, so a fair amount less than a 5th gen 4Runner, but they were also a smaller vehicle and around 3500 lbs curb weight. Which is just about 1500 lbs lighter than my TRD ORP as it sits.
I guess the only way to know is to try it.
02SE is offline   Reply With QuoteReply With Quote
Old 09-08-2023, 09:16 PM #35
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
How would a Bronco do on the Rubicon?
I think it depends on your modifications (based on your other comment regarding it being an early bronco). Most of them that my friends have are on at least 35's and have either Dana 44's or larger axles. In totally stock form - you would have a very bad time. I'd doubt that you'd make it past the first gate keeper obstacle and if you did you'd probably already have body damage.
If you have a typical EB with 35's and upgraded axles - you'll have fun and should go through no problem. I would not try it without rock sliders though unless you're on more like 37-40" tires. My own FJ40 doesn't have rock sliders, but it has 40" tires and I've cut 6 inches off the bottom of the original body, so it's pretty high clearance already and the frame rails act basically like sliders in most cases. Plus it's a trail only rig, so I'm okay with some body damage. If you have a nice EB - keep those sills off the rocks!!
The short wheel base will help a lot. It's a lot easier trail for smaller narrower vehicles.
My only other suggestion is that you should not to with the oem roll bar. It's just not strong enough in case you did have a bad roll over. It's really unlikely if you're careful, but a better modern cage is a really good idea.
Old 09-09-2023, 05:15 AM #36
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Yes absolutely, the Jeep XJ and Jeep JLU made the trail look pretty easy. Funny enough the XJ on 33s with a 5" lift was the only one in the group that cleaned the entire trail without a winch pull. He was also completely open in the front and driving a manual transmission! Solid axle suspensions are just so much more effective in rock crawling scenarios.
Also, as much as Toyota fans like to dog on Jeeps they for the most part are superior in the really hard stuff. I know this first hand and prefer to use my Jeep TJ Rubicon as the weapon of choice for very technical trails. You can't beat the comfort of the 4runner though for the 95% of the other off-road driving people typically do.
Congrats on completing the Rubicon. Maybe your trip will inspire Toyota to create a Rubicon version for the 6th gen. I was wondering if the XJ on 33’s was the same one kicking ass in Utah in this video. Pretty amazing. And as far as the Bronco goes, well, that’s another story in the same video. https://m.youtube.com/watch?v=VX7l3S...cCBicm9uY28%3D
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 09-09-2023, 10:29 AM #37
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I forgot to mention sliders, they are an absolute must and were used extensively. After I was done with the trail both were bent up a few mm making it pretty hard to open my rear doors. My passengers side slider also has a failed weld on one of the mounts. More things to fix.......
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 09-09-2023, 10:33 AM #38
Xtremluck's Avatar
Xtremluck's Avatar
Originally Posted by TRD PANTHER View Post
Congrats on completing the Rubicon. Maybe your trip will inspire Toyota to create a Rubicon version for the 6th gen. I was wondering if the XJ on 33’s was the same one kicking ass in Utah in this video. Pretty amazing. And as far as the Bronco goes, well, that’s another story in the same video. Showdown: Bronco vs Jeeps - Who Will Be Crowned the Ultimate Wheeler? - YouTube
Thanks, no that isn't my buddy but I think its a great example of how much weight and suspension articulation matters. Every time I drive my Jeep on the trail I'm reminded of that. It makes it up things barely spinning a tire that would require me to winch up on with the 5th gen.
Old 09-09-2023, 08:00 PM #39
Thanks, no that isn't my buddy but I think it’s a great example of how much weight and suspension articulation matters. Every time I drive my Jeep on the trail I'm reminded of that. It makes it up things barely spinning a tire that would require me to winch up on with the 5th gen.
That’s what Jeeps are great for and hard to beat in those environments. Nice that you have both. I know you do some heavy 4wheeling in your 4Runner and have it well set up for that. Regardless, it was nice to see you get through with your 4Runner without much difficulty.
Old 09-10-2023, 11:34 PM #40
Ctrulock Ctrulock is offline
Ctrulock is on a distinguished road
Red face
Very cool man
Ctrulock is offline   Reply With QuoteReply With Quote
rock , rubicon , thing , trail , truck
Taking my “Overloader” down a hard Jeep Trail (Slickrock, CA Trail Report) Xtremluck Off-Roading 26 12-06-2022 01:40 AM
Can 3rd gen do the Rubicon trail?? LS-4Runner 3rd gen T4Rs 10 12-03-2022 01:27 PM
Rubicon Trail robaroni Off-Roading 2 06-29-2016 10:46 PM
Anyone done the Rubicon Trail? hstexan General Discussions 1 03-09-2016 08:46 PM
Rubicon Trail Spring 2014 Trail Highlights & Report unlimitedFJ4 General Discussions 4 03-26-2014 05:34 PM
