Old 07-24-2024, 12:10 AM #16
WaterWhore84 WaterWhore84 is offline
WaterWhore84 is on a distinguished road
Hey Gang, new 5th gen 4runner owner here (inherited my dads) and excited to read this post as the horn works on the left and right but not in the center. Ill try replacing the clock spring first. Just wanted to say thanks thats all!
Cheers,
-Brett
WaterWhore84 is offline   Reply With QuoteReply With Quote
Old 07-24-2024, 10:31 AM #17
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Cheers,
-Brett
If the two horns sound, it is not the clock spring. Horns are wired in parallel after the clock spring. Save your money and your time.
I don't believe that 4Runners have a "center" horn; they only have two horns -- high an low tone. If you have a third horn it may be for an alarm, or the warning beeps when windows are open and you try locking the car.
fkheath is online now   Reply With QuoteReply With Quote
Old 07-24-2024, 11:03 AM #18
lazwa lazwa is offline
lazwa is on a distinguished road
Cheers,
-Brett
No worries Brett - welcome to the forum! There are lots of great resources here.
2015 Trail Edition
lazwa is offline   Reply With QuoteReply With Quote
Old 07-24-2024, 12:39 PM #19
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
I just started having this issue as well, and I have a 2015 Trail Premium. Dealer quoted me $1,300 to replace the clock spring assembly, but everything else on the steering wheel works just as others have detailed. Cruise, volume, phone buttons, arrows, etc all work flawlessly.
Does anyone have a step by step for the clock spring replacement? Only thing that makes me nervous is due to being around the airbag, but if it is simply disconnecting the battery and then replacing a part within the steering column that is no issue for me. Just would appreciate a little more guidance on the exact steps to know if this is something I want to undertake.
Thanks all!
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 07-24-2024, 12:52 PM #20
He means when the steering wheel is turned left and right. From his explanation of the issue it is reasonable for him to try to replace the clock spring as a fix.
Thanks all!
The problem with buying the genuine part is that it comes as an assembly with the steering angle sensor, which is the absurdly expensive part. Save the money and do it yourself. There are a number of guides on YouTube specifically for a 5th Gen 4Runner. I bought just the clock spring itself from Ebay and switched over the steering angle sensor which is very easy with a few plastic clips. If you have some basic tools you won't have an issue.
Regarding the airbag: Disconnect the battery and wait ~5mins and you will be fine. When you remove it, place it so that the airbag is facing upwards - so that if for whatever reason the airbag activates, it will activate up rather than the other way and become a projectile.
2015 Trail Edition
Old 07-24-2024, 08:59 PM #21
Originally Posted by lazwa View Post
He means when the steering wheel is turned left and right. From his explanation of the issue it is reasonable for him to try to replace the clock spring as a fix..
Ah, yes. I see now that I misinterpreted his description. Thanks for setting me straight.
Old 07-26-2024, 07:36 PM #22
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
Can you tell me where you bought it from on eBay...do you have a link, or can you confirm this is the right one?
eBay Link: Clock Spring Cable For 2010-2016 Toyota 4Runner Scion 84307-30090 Clockspring | eBay
Watched a few YouTube vids and seems pretty easy in reality.
Old 07-29-2024, 03:09 PM #23
That looks to be the right one yes, but I can't be 100% certain. I would also try to buy it from a reputable seller. I just tried to find the link for the one I used but unfortunately it says the listing has been removed.
2015 Trail Edition
Old 08-09-2024, 10:09 AM #24
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
New Wrinkle
Team - I haven't done anything yet to try and fix my horn issues I have been having as a result of what seems to be the clock spring.
Yesterday, as I was driving, nobody was near me so I just tapped the horn to see if it was still messing up. IT HONKED. Loud and proud, like nothing was wrong.
What would that indicate? I don't understand how it can go out, then come back if the clock spring is the issue.
Old 08-09-2024, 10:12 AM #25
Well, that's odd.. maybe there's a loose connection somewhere that is causing an intermittent connection?
2015 Trail Edition
Old 08-09-2024, 12:40 PM #26
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty is a jewel in the rough El Dusty is a jewel in the rough El Dusty is a jewel in the rough
El Dusty's Avatar
Its most likely your clock spring / ribbon of wires in there failing but not yet fully failed. The ribbon wraps and unwraps every time you turn the wheel and it does wear. As it continues to wear out it gives intermittent horn at certain steering wheel angles. I found mine wheel had a bad ground when pointing straight and replacing the clock spring solved it.
Just my two cents but it is your main air bag and your safety on the line to save on a part you may have to replace once or twice in the life of the vehicle. Anyone who can budget OEM should go that route. BOL
El Dusty is offline   Reply With QuoteReply With Quote
Old 08-09-2024, 06:29 PM #27
mbumpus11's Avatar
Real Name: Bump
mbumpus11's Avatar
Real Name: Bump
Don't get me wrong, I definitely think there is a clock spring issue, but it is odd that the horn would honk again with the wheel back in the "straight" position. I diagnosed the clock spring issue previously by being able to honk with the wheel turned either direction, but wasn't honking while straight. No issues with any buttons on the wheel, no lights on the dash, etc. Now I'm curious if it could be the grounding wire at the bottom of the wheel (when apart) going kaput.
Definitely listening about the safety item, and I'm capable of the replacement (check my thread although admittedly I haven't done nearly as much as many on the forum), so it isn't an issue of expense for the basic replacement or cheaping out. Just very odd in the way it came back to life!
Old 11-19-2024, 10:08 PM #28
SC01's Avatar
SC01 SC01 is offline
Real Name: Tyler
SC01 is on a distinguished road
SC01's Avatar
Real Name: Tyler
So I did this last week (switched out the clock spring) and it did not solve the problem. Still no horn sound. When I press my panic button the horns will activate as intended. Also after I reassembled the steering wheel, my dash lights up upon ignition to tell me that my multi terrain select is unavailable, and my steering wheel light illuminates as well.
I am in a 2012 TE.
Horn problem - with potential solution!-img_3905-jpg
2001 Limited (gone), 2012 Trail Edition. South Carolina.
"Impossible isn't a fact, it's an opinion."
SC01 is offline   Reply With QuoteReply With Quote
Old 01-20-2025, 04:00 PM #29
SC01's Avatar
Real Name: Tyler
SC01's Avatar
Real Name: Tyler
Bump. Can anyone help shed light on this? Thanks!
I am in a 2012 TE.
Old 01-21-2025, 11:16 AM #30
El Dusty's Avatar
El Dusty's Avatar
Can you clear the dash lights / codes using an obd scan tool? or do they come right back?
Did you use totyota or aftermarket parts for the replacement?
Start by checking your ground on the steering wheel with a multimeter.
horn , horns , integration , relay , steering
Potential problem (CV maybe) KurtL 3rd gen T4Rs 7 03-28-2015 08:03 PM
Do I have a problem here? (Rust potential) Raven 5th gen T4Rs 8 10-10-2014 04:40 PM
Potential Radiator Problem? tenro1 3rd gen T4Rs 4 12-22-2013 05:37 PM
Need help diagnosing a potential problem kobusLifeRemotely 3rd gen T4Rs 2 06-09-2012 08:20 AM
