Old 01-21-2025, 07:18 PM #31
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Originally Posted by SC01 View Post
Bump. Can anyone help shed light on this? Thanks!
I had similar lights on after removing my steering wheel and re-installing for a heated steering wheel mod. You may need to do a ZPC, zero point calibration. I did this and downhill assist calibration and it cleared the lights.
Yaw Rate and Acceleration Sensor Zero Point Calibration (for Regular People)
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 01-23-2025, 05:12 PM #32
SC01's Avatar
SC01 SC01 is offline
Real Name: Tyler
SC01 is on a distinguished road
SC01's Avatar
Real Name: Tyler
Originally Posted by El Dusty View Post
Can you clear the dash lights / codes using an obd scan tool? or do they come right back?
Did you use toyota or aftermarket parts for the replacement?
Start by checking your ground on the steering wheel with a multimeter.
- I can do this but did not think of trying it. I will.
- I used an after market clock-spring from clockspringexperts.com specifically for 2012 TE bc apparently they are slightly different depending on trim type.
- What setting should my multimeter be set to? I'm an electricity challenged person.
2001 Limited (gone), 2012 Trail Edition. South Carolina.
"Impossible isn't a fact, it's an opinion."
SC01 is offline   Reply With QuoteReply With Quote
Old 01-23-2025, 05:13 PM #33
SC01's Avatar
Real Name: Tyler
SC01's Avatar
Real Name: Tyler
Thanks! I'll take a look. Especially if I clear the codes and they come back again.
Old 01-23-2025, 06:44 PM #34
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty is a jewel in the rough El Dusty is a jewel in the rough El Dusty is a jewel in the rough
El Dusty's Avatar
All good, Set the multimeter to resistance / ohms / the little Ω symbol. In this mode it should beep and give you a resistance reading when you touch the probes to a continuous circuit. Test it on two points of a piece of continuous metal.
Now set one probe to the steering wheel metal and other to the door frame (put it to any non painted bolt / metal). It should give you a beep meaning the steering wheel is grounded to the the body of the car / continuous (good). If you cant get a beep, the wheel is not grounded you likely have a problem with clock spring still.
El Dusty is offline   Reply With QuoteReply With Quote
Old 03-16-2025, 12:26 PM #35
SC01's Avatar
Real Name: Tyler
SC01's Avatar
Real Name: Tyler
So I got the horn to work again. Once I took the airbag back off and tested the wires so there must have been some kind of problem when I reassembled everything after switching the clockspring. Now I just have to perform the ZPC tests.
horn , horns , integration , relay , steering
Potential problem (CV maybe) KurtL 3rd gen T4Rs 7 03-28-2015 08:03 PM
Do I have a problem here? (Rust potential) Raven 5th gen T4Rs 8 10-10-2014 04:40 PM
Potential Radiator Problem? tenro1 3rd gen T4Rs 4 12-22-2013 05:37 PM
Need help diagnosing a potential problem kobusLifeRemotely 3rd gen T4Rs 2 06-09-2012 08:20 AM
