Old 09-09-2023, 07:58 PM #1
Presa Canario's Avatar
Presa Canario Presa Canario is offline
Presa Canario is on a distinguished road
2023 ORP towing a 3000lb REI Airstream
My aunt has recently purchased a new 2023 ORP and the REI edition Airstream camper trailer. This trailer has a dry weight of ~2,750 pounds and can go as high as 3,500 with cargo/water/etc…. She wants it lifted as she stays mostly in primitive campsites “boondocking” as she calls it. She travels all over CO, WY, MT, OR, ID. I’m going to set it up with the Bilstien 6112’s in the front and the 5160’s in the rear. She doesn’t do any high speed off-roading, nor does she need to worry about maintenance on Icons or Kings. I’m going to put a set of 255/80/17 on her stock ORP wheels. My main question here is for the rear springs. This vehicle will be driven 75%+ with the camper in tow behind it. She’s already stated that she doesn’t care if it rides a little rough. She just doesn’t want the ass end to sag. She has a stabilizing hitch that came with the camper. It appears to be well made. I was going to get the Bilstien B12 1.5” lift 400lb heavy payload package rear springs. Will these be good enough for this setup or should I look at something else? This is the heaviest spring Bilstien makes.
Any help would be appreciated.
2017 TRD OR Premium // Icon 2.5 Ext trav w/ remotes and CDCV // SPC UCAs // Icon 2" rear springs // Icon 2.0 rear shocks // SCS Ray 10's // 285/70/17 Falken Wildpeak AT3W "E" Rated // RCI aluminum skids // SSO Sliders // Morimoto 4500K HIDs // LED interior // Canvasbacks //
Presa Canario is offline   Reply With QuoteReply With Quote
Old 09-10-2023, 11:55 AM #2
Ok. Got it.
Thanks.
Old 09-10-2023, 12:46 PM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
That T4R will tow 5,000 lbs. with 500 lb. weight on the hitch right out of the box. I'm sure it has plenty of clearance too, maybe more than the Airstream Basecamp. If there is a worry about sag that could be easily remedied with a weight distributing hitch. I use an Equalizer with my 23' and have no problems.
2023 ORP towing a 3000lb REI Airstream-dscn1652-jpg
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 09-10-2023, 01:08 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Might want to add a transmission cooler.
Old 09-10-2023, 01:34 PM #5
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
I would hope that if she were planning on pulling a trailer most of the time she would have gotten the towing package. Pulling the Airstream would also require a brake controller, frame hitch, larger alternator & battery, etc. Just my 2¢
Rich
Kentucky
Old 09-10-2023, 02:27 PM #6
Chumly Chumly is offline
Chumly is on a distinguished road
We have towed a 5000 lb boat and trailer setup on weekly basis on over the last 7 years on two different 5th Gens. Tongue weight is a shade under 450 lbs, and usually just my wife & I in the truck. Rear Sag is a non issue for us, just reduces the built in Rake. (I would discourage Lifting or Leveling if planning to tow frequently.) I would also discourage 33’s for towing. Our fuel economy towing runs 10-11 MPG on level ground if we keep it under 65 MPH. No issues towing that weight here in Florida since Overpasses and Bridges our on only climbs. With the Airstream, the windage from towing a big box can be a concern, in particular if your Aunt wants to go fast. But the 4runner is ok towing these lighter weights as long as you are realistic about its limitations.
Chumly is offline   Reply With QuoteReply With Quote
Old 09-10-2023, 10:07 PM #7
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Agree on the brake controller, the OP says that his aunt has a stabilizing hitch but am curious if the stabilizer or weight distributing hitch will work with a lifted vehicle. already use a drop down on my hitch ball and would have to lower it more with a lift.
Sorry Presa, not trying to derail, know you said your aunt was wanting a lift.
2019 ORP KDSS MagGrey RSG Sliders 255/75/17 KM2 MT/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 09-11-2023, 11:55 AM #8
MoreOutdoors MoreOutdoors is offline
MoreOutdoors is on a distinguished road
We’ve got a 2020 ORP and a 16’ Caravel so the weight we tow is more than the REI version. I second the weight distribution hitch. We got our WDH installed when we picked up our trailer along with the brake controller. We’re in CA and I don’t think we could legally leave with the trailer without a brake controller, so they’re necessary even without that being a law. If your aunt has it lifted before getting the trailer then the WDH should be able to be fitted to accommodate that height. Our hitch can move up or down to fit different height vehicles. Even if she got it lifted after the trailer, it should be able to be adjusted.
I will add that mirror extensions were needed for us. I drove it home for 2 hours on pick up day without any mirrors and could hardly see behind me on the freeway. Given the Caravel is wider so it may not be needed for your aunt’s rig.
As for the springs, I only have stock springs but would guess those Bilstein springs would be fine. Tongue weight of our trailer is ~450 lbs so with the slightly lighter trailer and tongue weight, those springs should work fine. You can confirm the tongue weight of the trailer to double check so that any load/weight in the back of the rig is accounted for with the spring rate in addition to the tongue weight.
MoreOutdoors is offline   Reply With QuoteReply With Quote
Old 09-11-2023, 12:39 PM #9
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
IMO - (having done lots of towing miles with my 4R) - Firestone Air Springs for the rear and a Curt Echo. Air bags install easily in an hour or two. No installation necessary for the Echo to control the trailer brakes.
That and a small air compressor is all you need.
A trans cooler could help, but is not necessary for a small trailer like that.
Good luck.
Handled my bigger trailer well. Only issue I really had was with power/gearing on the passes. I also had an F250, but usually still towed with the 4Runner because it's just so much easier to live with in the parks and around the places I want to go explore when we're camping. The 4R isn't a great tow platform, but it's perfectly well suited for a smaller airstream like your aunt has.
Old 09-13-2023, 11:35 AM #10
songdog songdog is offline
songdog is on a distinguished road
A brake controller is a must. You might be surprised as to how fast your brakes will wear without those trailer brakes. I hauled a light weight trailer w/no brakes with just a motorcycle on board to Florida once (truck not a 4runner) and had to do a brake job to make it back home. A lot of weight pushes you going down hills.
songdog is offline   Reply With QuoteReply With Quote
bilstien , camper , doesn’t , orp , rear
Airstream towing rector15 5th gen T4Rs 23 09-20-2022 09:51 AM
Towing an Airstream 22fb p00flakes 4th Gen T4Rs 8 06-03-2021 02:47 AM
Pulling an Airstream with a 4Runner TerraCrawler 5th gen T4Rs 2 04-06-2018 02:44 PM
More Input on 18'-20', 3000lb TT with 4.0 V6 Dougtoms01 4th Gen T4Rs 8 10-22-2012 08:54 AM
Towing an Airstream Trailer pickerdd 4th Gen T4Rs 13 11-03-2006 09:28 AM
