Old 09-18-2023, 11:25 AM #1
thefatcat thefatcat is offline
thefatcat is an unknown quantity at this point
Engine Sputter Going up Slight Incline
I have a weird issue with my 2016 4Runner Limited:
When going up a very slight incline at low speed I get a sputter / stutter in the engine or drive train (I cannot tell which). It occurs only when the engine is around 1100-1200 RPM and speed is anywhere between 15-30 MPH. It disappears as soon as I step on the gas a little more. It does not happen every time that I am on a slight incline but enough to where I am annoyed by it.
I just replaced the ignition coils and that did not do the trick like my mechanic and I thought. The spark plugs are maybe 2-3 years old. When I hook up my little handheld Motopower scanner it does not pick up any codes either.
Any thoughts on what the issue might be?
Thanks
thefatcat is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 08:46 PM #2
spartacus's Avatar
spartacus's Avatar
Thanks
The mechanic do any other trouble shooting? Check the fuel trims when driving uphill. start out with simple stuff. Clean engine air filter, Clean maf, check the vacuum lines. Clean the throttle body. Run some top tier gas in it see if that helps. Throwing in some new oem sparkplugs won't hurt any thing. How many miles on the truck?
Old 09-18-2023, 09:12 PM #3
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Stop throwing parts at it, as you are simply guessing and that gets expensive.
If you canít replicate it consistently and itís not throwing codes, then I would drive on.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 11:25 PM #4
djeepin djeepin is offline
djeepin is on a distinguished road
D is for hwy cruising. go uphill, add some gas and trans kicks out of overDrive into s4 or depend of speed and load, may be s3. it fast, but noticeable. EDUCATE YOURSELF BEFORE OPERATING ANY MACHINERY the best way to save transmission is to shift to D and click left to s4, and stay this way, untill you hit hwy
djeepin is offline   Reply With QuoteReply With Quote
Old 09-19-2023, 06:20 PM #5
No other troubleshooting performed. Dumb question..what is MAF? Vehicle just turned over 200K miles. No other issues other than this one.
Old 09-19-2023, 06:55 PM #6
spartacus's Avatar
spartacus's Avatar
The MAF sensor is on the intake tube downstream of the air box there are two screws holding it. Disconnect it and use a crc maf cleaner. It measures the air for the ecm. 200K is a good healthy milage to do this and replace the pcv valve if it's never been done before.
https://youtu.be/dk6CnOzIMOs?si=M0sBs6x6UW4u4oB7
Old 09-19-2023, 07:29 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
MAF = Mass Airflow Sensor. They can get dirty and cleaning can help in cases like this.
Old 09-19-2023, 08:43 PM #8
Jeremy556's Avatar
Jeremy556's Avatar
Start by putting your Toyota coils back. They almost never fail, aftermarket ones are garbage and will fail on you in the future.
As mentioned, using a good scan tool, drive and watch the A/F trims from the O2 sensors and misfire counters.
Old 09-19-2023, 08:54 PM #9
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Did you do a fuel pump recall? I did for my '14 LE and in a couple of years the "upgraded" pump was crap. Except i was throwing codes. When I brought it to a good shop, I was only making 3 PSI at my fuel pump. Maybe try to see if someone can to a fuel pressure check. No schrader valve on my fuel rail so you need someone with the right equipment.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 09-22-2023, 11:46 PM #10
No fuel pump recall for me.
Old 10-04-2023, 10:57 AM #11
Thanks for the input. I have noticed that if I am in s4 on side streets that the problem goes away. It only occurs when I am in D.
If it is a transmission issue....it should happen all of the time correct?
Old 10-04-2023, 11:22 AM #12
Could it be a torque converter?
engine , incline , issue , slight , sputter
Engine Sputter Going Up Slight Inclines thefatcat Problems & Warranty Issues 0 09-18-2023 11:19 AM
Engine sputter mtb97 3rd gen T4Rs 6 08-15-2015 03:45 PM
Engine sputter's makin me NUTZ! jado6006 Classic T4Rs 5 07-25-2013 04:58 AM
92 - Slight Engine Knock 92TXT4R Classic T4Rs 2 12-04-2009 02:18 AM
