Old 09-19-2023, 05:18 PM #1
tls3601 tls3601 is offline
Real Name: Tom
tls3601 will become famous soon enough tls3601 will become famous soon enough
Real Name: Tom
Minimal lift needed to run 285 70R17..
So I have a ‘19 Pro with the Eibach Pro spring lift kit, basically giving me about 1.5” of lift. Is this enough to run 33’ tires? Thanks for any input. Tom 👍
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
tls3601 is offline   Reply With QuoteReply With Quote
Old 09-19-2023, 06:21 PM #2
changing ride height does not affect tire clearance if you use all available wheel travel IE off roading or backing up/turning/while leaving a driveway at a decline. install them at whatever height you prefer. trim as needed.
IFS is not the same as a solid axle.
Old 09-19-2023, 10:17 PM #3
bassist bassist is offline
bassist is on a distinguished road
All you need to know…
4 Tips to ACTUALLY Fit Tires on Toyota IFS | 33s No BMC - YouTube
bassist is offline   Reply With QuoteReply With Quote
Old 09-20-2023, 10:58 PM #4
maxp0wer maxp0wer is offline
maxp0wer will become famous soon enough
You do not need any lift to run 33s. Have '18 Pro and only needed to remove front mud flaps and push front fender liners out a bit. If you want a lift, then go for it. But not needed for 33s.
maxp0wer is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 06:26 AM #5
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
On my 2018 Pro early on, I had a 1.5” Cornfed spacer up front and 1” rear. Ran 285/70-17’s with everything else being stock. Pros have the port front fender trim and I even left my front mud flaps on. Only very, very slight rubbing on max articulation. i.e.; my avatar. Of course, get a new alignment and see how much positive caster they can get out of the stock UCA’s. Then you can leave your mud flaps. You should have no issues.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 09-22-2023, 02:27 PM #6
Real Name: Tom
Real Name: Tom
Thumbs up
Thanks for everyone’s input, much appreciated!
Old 09-24-2023, 08:03 PM #7
1100 Remington Man's Avatar
1100 Remington Man 1100 Remington Man is offline
1100 Remington Man is on a distinguished road
I saw some where someone is running 255x80 17R on a New 4Runner TRD Pro this might be an option as he stated no rubbing.
1100 Remington Man is offline   Reply With QuoteReply With Quote
Old 09-24-2023, 11:03 PM #8
Running 285 70 R17 in 18 Pro with no lift. removed front mud flaps and pushed front liners forward a bit. No rubbing at full travel. Happy trails.
1.5” , lift , minimal , pro , run
Springs to support ARB & winch w/minimal lift mckennar 3rd gen T4Rs 9 02-10-2018 09:21 PM
Suspension Kit for minimal lift? WI_4Runner 4th Gen T4Rs 17 06-08-2017 12:27 PM
Upgrade Suspension / Minimal Lift Jabberjaw 5th gen T4Rs 39 02-15-2015 11:56 PM
Minimum Lift Needed for 255/80/17's with MINIMAL rubbing? High_Country 5th gen T4Rs 2 10-29-2014 10:39 PM
BJ Spacers Minimal Lift??? markls954runner Classic T4Rs 3 12-24-2010 03:20 PM
