Old 09-21-2023, 02:17 PM #1
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
2011 5th Gen 4Runner | Humming Noise
Hello, All!
My wife recently started hearing a humming noise while driving back and forth on her daily commute.
She said it was humming, to which I asked: "But can it carry a tune?"
(that's when the fight started)
It doesn't seem to be the normal humming one might expect from unevenly worn tires, etc. The tires are relatively new and I just had them rotated and balanced a month ago. I have ruled out wheel bearings which has me thinking it could possibly be from the rear differential.
Before I crawl up underneath it to check, I'd like a second opinion. I'm handicapped, getting down is easy - getting back up is another story.
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 09-22-2023, 08:45 AM #2
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
need more details. is it all the time, when the truck is moving, when applying gas only or just moving? etc. if you've eliminated the front end from possibilities and it is in fact coming from the rear you have really only the transmission, drive shaft, differential or rear wheels. depending on the specifics of your situation you may be able to rule out a couple options
when is the last time the transmission and differential fluid was changed
Old 09-22-2023, 02:00 PM #3
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
Thank you for the response!
The sound is definitely coming from the rear of the vehicle and is only when the truck is moving. The hum also does seem to correlate to the speed of vehicle and is louder at highway speeds.
There is no noticeable vibration and it doesn't sound like normal tire whine. It sounds somewhat like a tire rubbing on the plastic fender well splash guard but that would be more obvious. I've also considered the possibility that it may be exhaust related.
I plan on checking the transmission fluid level, belts, pulley's first, once I get it pulled in the garage this evening.
No CEL has coded, but will check things out via the OB2 just in case.
I am the second owner, and although the vehicle was meticulously cared for I didn't get the service records from the previous owner. I did, however, take it in to Toyota before purchasing, and had them check it from top to bottom with no deficiencies noted. I should probably get it in for a drivetrain service just to be on the safe side.
Thanks again!
Old 12-04-2023, 06:22 PM #4
Ph03n1x24's Avatar
Real Name: Mark
Ph03n1x24's Avatar
Real Name: Mark
Just a quick update!
I found the cause of the humming noise. (Front D/S "Bad" Wheel Bearing)
Problem solved!
back , humming , noise , started , tires
Humming/roaring noise from rear of my 2016 4Runner cannondale1974 5th gen T4Rs 9 05-26-2023 11:38 AM
humming noise while driving Eshua2 Problems & Warranty Issues 5 02-20-2017 10:51 AM
On off humming noise v8 4wd 4th Gen T4Rs 8 04-30-2015 03:25 PM
1997 4Runner SR5 - humming noise at 60mph werminghausen 3rd gen T4Rs 13 12-28-2014 08:33 PM
