Or…make a gravity bleed bottle from an old plastic OJ bottle, a few feet of 1/4” id clear vinyl tubing, and a couple of zip ties.
Remember to keep the bottle and tubing above the bleeder and you shouldn’t have any issues with air bubbles.
Use the ABS pump to do the rears and pull all the old fluid from the master cylinder. Just allow gravity to do the work on the fronts. Takes about 30 mins each for the fronts if you don’t have a friend to pump the pedal.
