Old 10-06-2023, 11:05 PM #16
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Or…make a gravity bleed bottle from an old plastic OJ bottle, a few feet of 1/4” id clear vinyl tubing, and a couple of zip ties.
Remember to keep the bottle and tubing above the bleeder and you shouldn’t have any issues with air bubbles.
Use the ABS pump to do the rears and pull all the old fluid from the master cylinder. Just allow gravity to do the work on the fronts. Takes about 30 mins each for the fronts if you don’t have a friend to pump the pedal.
1000MPH is offline   Reply With QuoteReply With Quote
Old 10-09-2023, 08:05 AM #17
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
I use the motive bleeder but I do NOT put fluid in it. Keeps it clean and easy. Just have to unhook it and refill the master every now and then.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
bleeder , brake , motive , thoughts , time
Motive Power Bleeder- OK to Use 5th Gen for Brake flush ? GNB 5th gen T4Rs 27 09-19-2018 02:08 PM
Motive Products Brake Bleeder on 5th Gen Mick1 5th gen T4Rs 13 01-19-2018 10:47 PM
What size brake bleeders are on these things? gtgt_bangbang Classic T4Rs 0 03-26-2015 08:14 PM
Motive Brake Bleeder Adapter nepa4r 5th gen T4Rs 0 09-02-2014 11:28 AM
Brake Speed Bleeders - Two Thumbs Up RiFF RaFF Classic T4Rs 1 05-25-2014 01:37 AM
