Old 09-26-2023, 11:02 AM #1
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Motive type brake bleeders?
Anybody use a Motive or similar brake bleeder kit? What did you use? Just generic DOT3? Did you end up filling the whole jug than pressurizing it and pushing it through? Do you just open a bleeder on one caliper at a time? any thoughts on this? Any negatives? Havent dont my fluid in6 years..so its way past time. Thoughts and comments appreciated, thanks guys!
Grug556 is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 11:40 AM #2
seatia seatia is offline
seatia will become famous soon enough
Real pressure bleeders have a diaphragm that separates the fluid from the compressed air and is by far the best way to do it.
The Motive bleeders work well as long as you don't run out of fluid.
Brake fluid seems to suspend very tiny, tiny air bubbles for long periods, which in turn becomes air in your system, so be very careful in handling the and pouring the fluid.
seatia is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 12:49 PM #3
Grug556's Avatar
Grug556's Avatar
is there a better bleeder than Motive to use?
Old 09-26-2023, 05:43 PM #4
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I have one but never use it. The rear brakes are self bleeding (look it up), I have my wife help bleed the front brakes. It's a super quick job
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 09-26-2023, 06:52 PM #5
Grug556's Avatar
Grug556's Avatar
YEah just want to change the entire fluid as easy as possible
Old 09-26-2023, 08:46 PM #6
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Brakes
I like the response from @Xtremluck . With the ABS pump pushing the fluid out the rear and a helper in the front it's quick and almost easy.
I have a Motive Extractor and it is a lot easier than the pressure bleeders. On the 4Runner it's only needed for the front. I also suction out most of the old fluid from the master cylinder with it. If you have other vehicles it may be worth the cost.
I use DOT 4 synthetic fluid.
Motive type brake bleeders?-motive-jpg
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-27-2023, 10:04 AM #7
Grug556's Avatar
Grug556's Avatar
what master cylinder part number did you need for the adapter?
Old 09-27-2023, 12:51 PM #8
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
No adapter, it does not connect to the master cylinder.
The vacuum line from the container is connected to each caliper bleed screw and the brake fluid is drawn out through the system.
I also use the vacuum line to draw from the bottom of the master cylinder to remove most but not all of the brake fluid. It can be used for the power steering pump reservoir too.
Link to instructions - Extractor Instructions - Motive Products
Old 09-27-2023, 05:14 PM #9
Whippersnapper02's Avatar
I have their power fill for the tranny and diff service and it works awesome but I made a mistake and should have bought the fill/extractor. I have been wanting one to brake bleeding but their site said they did not offer anything that fit the master cylinder/abs pump combo. Now it just says to send in your OD measurements for the Runner and my GTO. I think I'm going to order soon or at least contact them to see if they have anything.
Found it again:
Also some Toyota and Lexus use an integrated master cylinder abs unit where the ABS unit is either directly below the master cylinder or attached to the side. We do not have a kit that works with those vehicles.
Application Guide - Motive Products
Old 09-27-2023, 06:36 PM #10
BobsTrail's Avatar
Real Name: BobH
BobsTrail's Avatar
Real Name: BobH
I'm confused. No adapter needed.
The extractor does not connect to the master cylinder, only to the brake bleed screws through plastic tubing. It draws out the fluid from the system into its tank. I also use the tubing to remove fluid from the master cylinder or power steering pump.
@whippersnapper00 - Did not know about the power filler, looks good, may get one. Better than the small hand pump on top of the bottles. - Thanks.
Old 09-27-2023, 07:24 PM #11
Their kits are meant to pressure bleed instead of suction (negative pressure) bleed. Using it the way you do basically makes it like a Mityvac bleed system. There's nothing wrong with that method though.
It makes things a lot easier especially if you have an air compressor...which I don't.
Old 09-28-2023, 10:56 AM #12
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
In the past , I used the Motive Power Bleeder on Volvo's, Toyota's and a Corvette. This over a period of over 5 years per vehicle. Worked like a charm, never any issues.
On my 2015 4Runner TRD , I have my garage perform the work . Heck, it's less than $150.
Suggest purchasing a brake fluid tester- they're not expensive. No need to replace /flush if the fluid is good.
GNB is offline   Reply With QuoteReply With Quote
Old 10-04-2023, 08:06 AM #13
YelloLab's Avatar
YelloLab YelloLab is offline
YelloLab is on a distinguished road
YelloLab's Avatar
I use te ALLSTAR PERFORMANCE (ALL11017) bleeder bottle with check valve and magnet. Works perfect one man flush.
YelloLab is offline   Reply With QuoteReply With Quote
Old 10-06-2023, 11:30 AM #14
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
dont waste money on it.. its so easy to do it on a 4runner without all these fancy tools
im glad some of you have had good experiences w/ the Motiv bleeder but from my experience the stupid top cover never locks down evenly to create a good seal.. adjust one side and the opposite side leaks vice versa
my best tool for the job, my 9 yr old that can pump his little legs to exhaustion
the rears have pumps so all you have to do is hold the brake pedal and it'll squeeze it out for you
just make sure you never let the reservoir run out
1jzgte is offline   Reply With QuoteReply With Quote
Old 10-06-2023, 11:31 AM #15
Walmart bleeder
give this a shot if you want.. ive never tried it
bleeder , brake , motive , thoughts , time
Motive Power Bleeder- OK to Use 5th Gen for Brake flush ? GNB 5th gen T4Rs 27 09-19-2018 02:08 PM
Motive Products Brake Bleeder on 5th Gen Mick1 5th gen T4Rs 13 01-19-2018 10:47 PM
What size brake bleeders are on these things? gtgt_bangbang Classic T4Rs 0 03-26-2015 08:14 PM
Motive Brake Bleeder Adapter nepa4r 5th gen T4Rs 0 09-02-2014 11:28 AM
Brake Speed Bleeders - Two Thumbs Up RiFF RaFF Classic T4Rs 1 05-25-2014 01:37 AM
