Old 09-30-2023, 09:44 PM #1
4RExplorer 4RExplorer is offline
Real Name: Ted
4RExplorer is on a distinguished road
Real Name: Ted
High moly grease on spider joints?
For lubricating the drive shaft, this thread:
Beginner Fluid Maintenance
recommends Mobilgrease XHP 322 Mine for lubricating the slip yoke, and Lucas Oil Red 'N' Tacky #2 (which I gather is sometimes sold without the "#2" on the product label) for the spider joints.
My understanding is that Mobilgrease XHP 322 Mine is preferred in the slip yoke because it has higher molybdenum disulfide than the Red 'N' Tacky.
Is there any disadvantage to using the XHP 322 in the spider joints as well? The Mobil product data sheet says it is good for "general purpose chassis lube":
https://www.mobil.com/en/lubricants/...e-xhp-322-mine
2019 4Runner TRD Off Road
4RExplorer is offline   Reply With QuoteReply With Quote
Old 09-30-2023, 10:16 PM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
as long as it has moly in it, and you are maintaining your drivetrain at least once or twice a year, it doesnt matter.
I use mobile 1, valvoline, and red N tacky....basically whatever is in my grease gun at the time and whatever is the cheapest i can get on amazon.
Old 10-01-2023, 12:18 PM #3
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Spicer/Dana who is a very large manufacturer of ujoints recommends their own grease which uses a calcium sulfonate base and no moly.
MolyD should be less than 5% to prevent ujoints from binding up as per ExxonMobil Commercial Vehicle Lubricants Applications Engineer Paul Cigala
seatia is offline   Reply With QuoteReply With Quote
Old 10-01-2023, 03:07 PM #4
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Originally Posted by seatia View Post
Spicer/Dana who is a very large manufacturer of ujoints recommends their own grease which uses a calcium sulfonate base and no moly. MolyD should be less than 5% to prevent ujoints from binding up as per ExxonMobil Commercial Vehicle Lubricants Applications Engineer Paul Cigala
Does Spicer grease leak lighter oils out of the grease gun like so many other grease products?
DougR is offline   Reply With QuoteReply With Quote
Old 10-01-2023, 03:47 PM #5
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Moly is needed for sliders, NaGl2 is called for spider joints by Toyota's manual. I use this Harbor Freight Moly goop for sliders for years without any issues:
<<<< is offline   Reply With QuoteReply With Quote
Old 10-01-2023, 10:02 PM #6
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
This is spot on and I have 340K miles on a 2014 SR5 to prove it. I shoot the spider joints on the driveshaft every 5K miles.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 10-02-2023, 10:39 AM #7
Real Name: Ted
Real Name: Ted
I found an article saying a moly grease can be used in "any component" in an on-highway, heavy-duty vehicle, but the article quotes Paul Cigala as saying that U-joint manufacturers specify a molybdenum disulfide content of "5% or less" to avoid binding in the needle bearings inside the U-joint:
The fundamentals of truck and trailer grease application | Commercial Carrier Journal
The moly is especially good in sliding applications like the slip yoke because it bonds to the surface of the metal, creating an extra layer for sliding over. Mobilgrease XHP 322 Mine has 5% moly content, so it would probably be OK in the U-joints. But maybe the best way is to just have two grease guns for the two different types of components, and lubricate often.
Thanks for all your comments.
Old 10-02-2023, 12:42 PM #8
One can overthink this, but basically 2 greases would probably be best.
There is a reason why Harbor Freight sells moly grease for $8, Spicer grease is min of $20 and a grease like Krytox is $500, in all cases for a 14oz tube.
General rule Better >$. You would be amazed at sone of the higher end tube prices.
MolyD is a mineral and has particle sizes. Google it.
I used MolyD oil for machining and drilling stainless, can't beat it.
For all suspension parts, I use Moly, joints it's Spicer.
I hate changing joints almost as much as paying someone else to do it.
Old 10-02-2023, 03:00 PM #9
Whippersnapper02's Avatar
Any off the shelf NLGI #2 grease will do just fine.
joints , red , spider , tacky , xhp
Clearance problem with spider grease fittings on propeller shaft service Grug556 5th gen T4Rs 24 11-15-2022 09:55 PM
Can I use EP moly grease on all the drive shaft grease zerks Pyral 3rd gen T4Rs 3 07-18-2021 12:46 AM
Favorite Moly EP Lithium Grease? Cvett95 3rd gen T4Rs 3 09-18-2019 12:54 AM
Let’s talk about grease Superlube vs Moly Fortified assassin General Discussions 3 09-14-2018 05:08 PM
Using Liquid Moly Longtime High Tech 5W-30? nytefog 4th Gen T4Rs 23 05-21-2015 11:03 PM
