Originally Posted by AuSeeker
Sometimes the rear brake drum/disk can be rusted to the axle flange, the drum/disk has 2 thread holes on the flange area of the drum so you can use 2 bolts to help pull the drum/disk off....tap a few times with a hammer and if needed run the 2 bolts in the holes and tap some more, rinse and repeat until you get the drum/disk broke free from the rust, I don't remember the bolt size, maybe someone else will chime in with the size.
BUT whatever you do...make sure you back off the parking brake shoes via the hole and using the screwdriver, if you don't and they hang up pulling the disk and it will damage the parking shoes mounting hardware and you will have to replace that hardware, which isn't fun because the axle flange is in the way and make it rather difficult!!
Originally Posted by Captain Spalding
The video posted shows exactly what happens when you don't back off the parking brake shoes as I mentioned in my previous post, the issue the guy has is he correctly used the bolts to help pull off the drum/rotor....BUT by not backing off the parking brake shoes he had a hard time getting it off, if the shoes were backed off properly once any rust between the drum/rotor is broken free the drum/rotor should come off relatively easy...but if you noticed in the video he had to keep using the bolts until it let loose of the parking brake shoes....when he says the spring retainer that secures the shoe came loose and was rubbing the back of the lugs....the retainer wasn't loose....what happened was by him forcing the drum/rotor off without backing off the parking brake shoes it pulled the brake shoe so hard it "straightened" the "pin" he showed (he claims it's the wrong pin, which it isn't) allowing the spring to push the spring retainer out far enough to rub against the back of the lugs/rotor.
So basically he created more work for himself that wasn't necessary because he failed to back off the shoes, I noticed he didn't show the pain in the butt it was to correct his mistake, it would of been nice if he had showed how difficult it is to replace that pin/spring and retainer with that axle flange in the way, it would stress how important it is to back off those shoes!!
I really don't think he was even aware that he caused that problem and needed to back off the shoes before removing the drum/rotor since he blamed it on the pin being the incorrect part!!
