10-09-2023, 01:39 PM
Oooohweeee! 255/80r17
Taller than I expected. Hope they fit…
10-09-2023, 01:41 PM
Nice. Love my 255/80
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
10-09-2023, 03:28 PM
They fit with no rubbing on the body mount or front fender liner.
The spare is another issue. I was able to shoehorn it in there but with my hitch installed I could only manage ~1/4” clearance with the Swaybar and KDSS cylinder. I guess that means it fits but we’ll see if it rubs anything under articulation.
10-09-2023, 03:46 PM
What size are your previous tires? Curious how you like the handling of the skinny tires vs wide(if you had 285s)
10-09-2023, 04:14 PM
I quite literally just had them installed but they get really good leaving the tire shop 😁. I will definitely update this post when I log some miles. It’s set to rain for the next week and I should be towing my 5k lb travel trailer over some twisty roads by the end of the month.
I was running 265/70r17 BFG K02s in C load for the past 60k miles.
10-10-2023, 12:15 AM
I've been running a 285/70R17, E rated tire in the stock spare location for years with zero issues. There's minimal clearance around it, but it seems to be enough.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
10-10-2023, 09:35 PM
we run those in the c rated 34/10.5-17 flavor. they were definitely squirrely for a while/we got used to it compared to e rated 285's. otherwise theyve been great.
10-10-2023, 10:52 PM
do you think one felt more stable or handled better on and offroad? any mpg difference compared to 285's? and do you have any preference between the 2 widths given all factors?
10-10-2023, 11:15 PM
softer offroad. dont look as good as 285. otherwise everything feels the same. oh steering wheel feels easier to turn.
10-11-2023, 12:29 PM
I can’t tell from the pictures, but are you stock otherwise? At least in the suspension/lift/clearance portion.
10-11-2023, 10:57 PM
I’m not. I’m running Dobinson’s IMS shocks and 302/505 springs.
10-11-2023, 11:05 PM
A quick update- it’s only been 2 days but my first impressions are very positive. I’ve driven some freeway and around town miles in rainy wet weather for the past two days. The tires have not slipped yet and have tracked very well in both environments. There hasn’t been enough standing water to comment on hydroplaning at this point. I’ve also had them on a bit of gravel and they hold/throw way fewer rocks than my KO2s did. Braking does feel a bit more labored but I’m not certain yet if that’s the tires or if I’m looking for a negative.
Also, I was worried they’d look funny as this is my first set of tall skinny’s but I think they look great. They fill up the wheel well nicely, add sidewall, and fit the factory rims without contacting the UCAs. A win win.
10-11-2023, 11:59 PM
Take a look at close to full steering wheel lock and suspension compression.
10-12-2023, 12:18 AM
255/80's are the best tire size!
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
The close-up photo above is at/near full lock. There’s quite a bit of clearance at that point while on flat ground. I’ve tried to flex out the suspension a bit but have not yet been able to fully compress my front end while turning. I’ve turned at full lock in both directions while driving forward and in reverse over uneven ground and have not yet found any rubbing.
Do you have personal experience with these tires and rubbing? What was your experience?
