Old 10-18-2023, 05:31 AM #1
ROLAND1955's Avatar
ROLAND1955 ROLAND1955 is offline
ROLAND1955 is on a distinguished road
ROLAND1955's Avatar
4 Runner balancing issues
Would like to hear some comments from you about the following. I have a 2010 4 Runner, SR5. Until about a week or so ago I had been running Yokohama HT Geolanders. No issues, Tires had just under 60K miles on them and the tread was still good but they were now 7 years old so I decided to put new tires on. I went to Discount Tire and put on a set of Michelin Defenders LTX M/S. Immediately I noticed a smoother quieter ride... until I hit about 62 mph. From 61 to 63 or 64 there was a noticeable vibration in the steering wheel. Took the vehicle back to Discount Tire. The tech came out and told me that two of the tires were not balanced properly during the initial installation, but he had rebalanced them and they were good to go. That was last Friday. This weekend my wife goes to visit the grand kids about 145 miles away. Calls me from the road and tells me there was vibration in the steering wheel when she hit around 62-63 miles an hour. Vibrates only at that speed, no vibration below or above that speed. So now I have to take it back to Discount Tire again, this will be my 3rd trip. Anyone else run into anything similar. I don't think I have an out of round tire or else it should vibrate all the time. Don't think there's a problem with the wheels or there should have been a problem with I was running the Yokohoma's all those years.. So it has to be the tire right? Read somewhere that I need to get the road force balanced. But to be honest I have no idea what that is. I just want my 4 Runner to run nice and smooth like it has for all these years. Any suggestions would be greatly appreciated. Thanks in advance.
ROLAND1955 is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 07:38 AM #2
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Road force. I had to do it every time even with the same nice Michelin's as you have.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 09:44 AM #3
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Could possibly be a tire out of round. Or they just don't know how to balance tires well. How much weight did they use?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 12:20 PM #4
Metal Head Metal Head is offline
Real Name: Eric
Metal Head will become famous soon enough
Real Name: Eric
Call around to the Discount tires in your area and see if they use road force balance as standard. Not all the shops have them, I specifically went to one that did.
If you got your tires from them with the lifetime balancing warranty another store with the RF balancing machines should honor it.
Discount Tire | Tires and Wheels for Sale | Online & In-Person
Metal Head is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 02:00 PM #5
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Discount Tire should have Road Force Balancer machines, the key is to find an employee who knows how and is willing to use it to it's full capability. Including calibrating the machine, match-mounting, and turning off the 'Smart Weight' feature.
If that doesn't do it, then you probably have a tire uniformity issue.
02SE is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 03:43 PM #6
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Had the exact same issue with my local tire shop. Had them re-balance twice and still had the shakes at 90km (Canada). They were the ones who installed my Falken Wildpeaks when new. Had my local Toyota dealership address the issue and has been normal ever since. For some reason they seem to have better equipment to fix the wobble? Dunno! FWIW.
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 10-19-2023, 12:44 AM #7
5Sport 5Sport is offline
5Sport is on a distinguished road
I just took mine back for the second time with Falken Wildpeaks. The idiot tried telling me the steering wheel shake was because they were A/Ts. I almost lost it. I've run Toyo A/T IIIs and Geolanders without issue.
What it was is they were lazy and instead of using weights inside and outside the rim, they used a single weight. It was them just being lazy. I'll take it on the frwy tomorrow to see if the shimmy is gone.
5Sport is offline   Reply With QuoteReply With Quote
Old 10-19-2023, 04:05 PM #8
ROLAND1955's Avatar
ROLAND1955's Avatar
Update: So I took my 4 Runner back to discount tire yesterday.. Guy at the counter acknowledged that he realized this was my 3rd trip back for this issue and tells me he's putting his most "experienced " tech on it. I ask him if they use road force balancing and he tells me that's all they use.. Before he drives the vehicle away into a bay, I ask him, what if you don't get them balanced this time, what happens then. He tells me that then they would start to look for 'mechanical' issues like a wheel bearing issue or issue with a brake caliper.. I pretty much stopped him right there and reminded him I had zero balance issues on the Yokohama's and that the only thing that has changed is we've gone to a new set of tires... so this is NOT mechanical.. 45 minutes later he tells me basically they started all over, removed all the weights that were on there, road force balance and as he put it, made sure the new weights they used wouldn't come off and he thought my issue was resolved. He was right. Drove the 4 Runner home ( about 15 miles ) at various speeds including 62 to 65 and absolutely no shimmy. So happy to get this resolved but it also shows that they didn't really balance them correctly the first two times. In any event, it seems to be good now, so up next probably going to have to put on a new set of brakes. Still on the original brakes at 103K miles. Last tire rotation had them check and the pads were down to 4mm.. so it's coming. lol
Old 11-13-2023, 11:57 AM #9
mrmike7189's Avatar
mrmike7189 mrmike7189 is offline
Real Name: mike
mrmike7189 is on a distinguished road
mrmike7189's Avatar
Real Name: mike
I was constantly getting my Bridgestone dueler HT;s balanced . awful ride
Since they were about the worst tires I ever drove in winter snow and ice, I replaced them with only 36k miles . NOT sad to see them gone. Shame on Toyota for putting such crappy tires on a new 4 runner!
I bought Yokohama Geolanders and the rest is history. Much happier with the Geolanders as you were. I hear good things about the michelins on 4 runners. Lets hope you can dial them in and get some good miles on them.
2020 SR5 4x4
mrmike7189 is offline   Reply With QuoteReply With Quote
Old 11-13-2023, 02:22 PM #10
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
4Runner sensitivity to front wheel balance is a well known issue.
When you get your wheels Roadforce balanced you have to be specific on what you want to get the best results. Ask the tech what the Roadforce numbers are for each wheel - these basically tell you how out of round the tire is. From my experience, under 10 is good, 10-20 is acceptable, over 20 is bad. The larger and/or more aggressive the tire is, the more likely the tires are to be out of round and have worse Roadforce numbers. Once you have the Roadforce numbers, tell the tech to put the lowest on the front and highest on the rear.
I started doing this years ago and it greatly reduced the 55-65 steering wheel shimmy. I still get it on cold mornings when the truck has been sitting - it usually goes away once the tires warm up.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
discount , miles , tire , vibration , years
Tire balancing issues Dollar Retriever 5th gen T4Rs 14 01-05-2022 09:34 PM
New tire balancing issues... again Derek 4th Gen T4Rs 8 09-28-2020 05:32 AM
Anyone have Falken Wildpeak balancing issues? newton22 4th Gen T4Rs 17 06-05-2020 11:46 AM
SCS Ray 10 & BFG KO2 Tire Wheel Balancing Issues NYSLC93 5th gen T4Rs 17 09-05-2017 02:18 PM
Tire Balancing Issues - Seeking Advice Derek 4th Gen T4Rs 27 04-24-2017 11:54 AM
