Originally Posted by NB17Limited
It’s not a newer model thing. None of them come stock with anytime fog lights or fog lights that can be used with just DRL on
My new 23 TRD Sport with LED headlights and LED upgrade fogs has a button on the left side of the steering wheel that will allow the fogs to work with high beams.
Round switch on the stalk allows fogs to be used on low beams.
Switch on the dash to the left of the steering wheel allows the fogs to work on high beams.
This does not allow the fogs to work on DRL or marker light position though, but i am somewhat confident you can wire it with a relay to trick the ECU to also run the fogs with DRL and markers. I have not looked into rewiring yet, its in the future when i do some floorboard lights and a few other things have the lower dash pulled out.
Here is a pic i just went out and took. This is Low beam, high beam, and fogs. Completely 110% bone stock its brand new i have not wired anything.
