Old 10-25-2023, 11:34 AM #1
4skrunner 4skrunner is offline
4skrunner will become famous soon enough 4skrunner will become famous soon enough
Bilstein 6112 with 1/4” top hat spacer
Has anybody ran this combo and or more importantly, cycled the suspension with a 1/4” or 1/2” top hat spacer? I’m currently running 6112s at the top clip with 600# springs. The only thing is I’m only getting 2” of lift but I love the ride qualities with the 600# spring. I don’t want to move to a 700 or 650 pound spring in order to maintain my ride quality. Therefore I’m looking into adding a thin top hat spacer. Being that the 6112s add an extra inch of droop, I’m concerned that adding a spacer may lead to too much extension.
So my question is, has anyone ran a similar setup and fully cycled the suspension? To ensure no CV or ball joint bind at full droop? And no issues at full bump? Or does anyone know if a preload collar exists for the 6112s that’ll give me a bit more height?
I’m also considering adding a small spacer/washer below the top hat nut in order to slightly limit down travel.
4skrunner is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 02:33 PM #2
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
Check Wescott Designs for a preload collar.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 04:40 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
"Tinkerer's Adventure" youtube has a discussion of Toyota IFS suspension, cycles suspension and discusses spacers. You might take a look and see if it answers your question.
I'd link it but I'm technically disadvantaged!
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 10-25-2023, 05:36 PM #4
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
what setting do you have your 6112s on? aren't there multiple clip height settings so you shouldnt need a spacer?
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 06:05 PM #5
That’s exactly what I need but pretty pricey!
Old 10-25-2023, 06:06 PM #6
I’m familiar with the vid thanks for the heads up!
Old 10-25-2023, 06:07 PM #7
Top clip. Maxed out but only gave me 2”
Old 10-25-2023, 06:52 PM #8
I believe the cv's will be fine. but the ball joint in the UCA is gonna be at a pretty good angle at full droop. whatever you add to the top, add a spacer to your bump stop so you dont over compress the shock. I used my plasma cutter to cut my own bump stop spacers, just some 1/4" sheet metal. (i did the same idea but with the king shocks so i woudnt need to change the spring preload. bought the king top hat spacer from ekstrom design) Ekstrom Design & Fabrication Corporation -- A Coachbuilder Company -- – Shop Coachbuilder
Old 10-29-2023, 08:47 PM #9
Ended up tossing the spacer in. It actually measured out to be 3/8” but surprisingly only gave me about 1/2” of lift. So I’m at 2.5” of lift up front which is what I wanted. At full droop there is not issues. Wheel spins fine and turns lock to lock no issue. Didnt test full bump because I didn’t feel like breaking the strut down but I was more so worried about droop.
6112s , hat , i’m , spacer , top
Bilstein 6112 & OME906/Bilstein 5100 BikeDestroyer 3rd gen T4Rs 12 09-05-2019 08:47 AM
Installing 1/4 spacer on top of 6112's on my own SoFloT4Run 5th gen T4Rs 5 01-16-2019 05:40 PM
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
Anyone running a 1" spacer with the Bilstein 6112 setup ? JOEYD215 5th gen T4Rs 1 05-23-2017 10:14 AM
Bilstein 6112 vs Bilstein 5100 TotalAutomotiveLV General Discussions 1 06-02-2015 05:35 PM
