Old 10-31-2023, 12:43 PM #1
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
why AC compress engaged when I switch to blow warm air to windshield.
I didn't notice this during summer. But now in winter here, when I start turning on heat/warm air, I notice other settings are working fine, but when I switch the setting to let warm air blow to the front windshield, I can hear the A/C compressor has been engaged as my AC compressor currently doesn't work and make a big noise. I know it is bad, I just don't want to fix it during the winter as I don't need it. But why it is engaged when in this one setting? I am sure I didn't turn on AC at all, and only warm air came out.
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 10-31-2023, 01:00 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
When selecting air to the windshield it's activating your defroster/dehumidifier. In order to work properly it turns on the AC to aid in dehumidifying.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-31-2023, 01:39 PM #3
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
FWIW - If you want to wait until summer to fix your AC compressor, you could disconnect the wiring to the AC clutch for a temporary disable. Easiest way to do this is to pull the fuse. It's under the hood IIRC in the fuse block there and probably marked A/C. That might get you through winter until you can fix in spring.
Good luck.
Old 10-31-2023, 02:45 PM #4
cbreze's Avatar
cbreze cbreze is offline
Real Name: Jim
cbreze is on a distinguished road
cbreze's Avatar
Real Name: Jim
Not sure about newer rigs but in my 2012 SR5 there is a setting one notch back from full defroster. I believe it divides the flow between floor and windshield. In this position the AC does not turn on. I use it frequently in winter. It puts an adequate amount of air on the windshield.
Lovin' my 4R
cbreze is offline   Reply With QuoteReply With Quote
Old 10-31-2023, 02:46 PM #5
Golfpilot Golfpilot is offline
Golfpilot will become famous soon enough
There is nothing to repair, seems to be normal. as soon as the fan is switched on and one of the two windshield positions is selected, the air conditioning compressor runs. i have also recently investigated:
Condensate water even with AC off?
2019 4Runner TRD Off Road Premium, one of the few 5th gen in europe.
Golfpilot is offline   Reply With QuoteReply With Quote
Old 10-31-2023, 02:51 PM #6
I would also prefer a different behavior, most of the time airflow to the windshield is enough without air conditioning. I don't want to drive with air conditioning all the time.
Old 11-12-2023, 02:56 AM #7
Can you explain more about this? Do you mean there is a button can do this?
Old 11-12-2023, 04:48 AM #8
I think it means the foot + windshield position, but my 2019 TRD Offroad Premium engage AC in both positions:
Old 11-15-2023, 02:37 AM #9
cbreze's Avatar
Real Name: Jim
cbreze's Avatar
Real Name: Jim
Yes, this is what I meant. You explained it a bit better. my SR5 being a 2012 model year apparently works differently then the newer models in this regard.
Lovin' my 4R
Old 11-15-2023, 04:32 PM #10
@Golfpilot , unfortunately, on my 2010 limited, both setting will have AC kicked in. Maybe the best way is to disable the compressor by pulling out the fuse.
Old 11-15-2023, 04:40 PM #11
Good luck.
Will it cause any problem without AC to dehumidify the air? I am worried it actually fog the windshield even worse?
Old 11-15-2023, 10:01 PM #12
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Generally warm air alone is enough to defog, it’s just that A/C helps speed up the process and removes moisture from the air in the car to help prevent from fogging back up.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 11:00 PM #13
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Running the AC compressor during defrost cycle has been the norm in vehicles for years. As mentioned, it helps dehumidify the air and speeds up defrosting. Running the compressor while defrosting also keeps the AC system from just sitting for months on end; which can cause seals to dry out, and premature failure of the compressor.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
air , compressor , engaged , warm , winter
OEM 3rd gen windshield wiper switch/stalk SurfnSun For Sale: T4R Items 2 03-31-2022 09:08 PM
Windshield defrost switch Firesq14 5th gen T4Rs 11 08-27-2019 05:21 PM
Sweltering in Florida: AC blow only warm air bubashep 4th Gen T4Rs 9 09-01-2013 09:00 AM
Windshield defrost switch won't go all the way over... cliffw2000 3rd gen T4Rs 0 12-26-2009 01:59 AM
DAC switch engaged by mistake lin 4th Gen T4Rs 3 01-29-2005 08:25 AM
