Old 11-29-2023, 03:59 PM #31
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Originally Posted by lewis26 View Post
Could you have used the BMW switch with a relay instead?
Maybe?!? I just wouldn't know how to wire it up with a relay...
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 11-29-2023, 06:53 PM #32
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Is the heated steering wheel controlled in any way - or is it just on or off?
Old 11-30-2023, 10:48 AM #33
lewis26 lewis26 is offline
lewis26 is on a distinguished road
You'd need to use a latching relay that resets when the vehicle voltage is removed.
So the BMW momentary switch would create the 12v signal to "latch" the relay on, and would stay on until the 12v line voltage drops when the car turns off.
lewis26 is offline   Reply With QuoteReply With Quote
Old 11-30-2023, 01:11 PM #34
The one I chose was only on or off. Though there is an option for a 'dimmer' switch where you can adjust the intensity but it required more parts. I chose the basic on/off because it had less parts. Where I installed, inside the steering wheel, there isn't much room.
Old 11-30-2023, 01:11 PM #35
Is there a link you can send me for this relay? It is something I would like to look into, thanks!
Old 11-30-2023, 01:32 PM #36
Got my switch wired and taped up to take up minimal space.
Heated steering wheel mod - success!-switch1-jpg  Heated steering wheel mod - success!-switch2-jpg
Old 11-30-2023, 01:55 PM #37
https://uk.rs-online.com/web/content...g-relays-guide
Old 12-02-2023, 06:05 PM #38
4thGenCanuck 4thGenCanuck is offline
4thGenCanuck is on a distinguished road
Following
4thGenCanuck is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 12:07 AM #39
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
A ltching relay with monetary pulse, or this: Latched On/Off Output Using a Single Momentary Negative Pulse - Positive Output Relay Wiring Diagram
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 11:19 AM #40
The wrap finally showed up and had some time this weekend to put it on. It is not perfect but overall I am pretty happy with how it turned out. Here is also a shot of the stitching and another shot of the switch and how easy accessible it is for my fingers.
Heated steering wheel mod - success!-done-jpg  Heated steering wheel mod - success!-stitch-jpg  Heated steering wheel mod - success!-button-jpg
Old 12-04-2023, 12:47 PM #41
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Stitching looks great, love the overall look. Did you buy it precut and ready to sew on? Nice work man
Old 12-04-2023, 12:52 PM #42
Yes I just bought the cover which needs to be stitched on. Lots of options out there but I went with one from East Detailing.
I believe the wrap would fit a lot better if I didn't remove the previous leather wrapping. This product from East Detailing is meant to go over existing steering wheel leather so I had a bit more slack I had to play with but overall I am very happy with the finished product.
The link in my very first post, the OP installed the heat pads over existing steering wheel and wrapped over. Would still work either way. If I were to do it again I would probably do it over the existing steering wheel.
Old 12-12-2023, 04:53 PM #43
So I was able to remove the factory steering wheel and install the new steering wheel. I did a mock up of the wiring where I plugged in the wires onto the pins without inserting yet into the connector (2nd pic). It all worked great with no issues when tested. The 2 wires went into the 2 connectors behind the airbag. I ran a power wire from an empty slot in the fuse block to the empty spot in the clockspring pin as previously posted. I also ran a ground to the 2nd empty slot in clockspring pin as also previously mentioned.
Now the hiccup I ran into. The 2 wires behind the airbag fit perfectly into the existing white connectors with no issue. I was under the impression that I could do the same for the black connector on the backside for the clockspring. Unfortunately the 2 wires do NOT fit into the black connector. If they fit this mod would have been a success.
Now I am looking for an extra black connector with pigtail harnesses already installed. Does anyone know the part number? If I get this, I can depin the extra connector and install them into existing connector and this mod will be done and finished. So this is where it's at for now...
Heated steering wheel mod - success!-installed-jpg  Heated steering wheel mod - success!-2wires-jpg
Old 01-03-2024, 08:50 PM #44
So I found a solution to my issue about the 2 wires going into the back of the clock spring! I found this male to female 12pin harness on AliExpress! It took a few weeks for shipping but showed up today. These fit perfectly for what I require it for. Only downside, which isn't a huge deal is they are longer than what I need. They mate perfectly with oem connector and actually clicks in place unlike other cheap overseas options. Here are a few shots of it. I will install this weekend so this mod can finally be done! All I need to do is splice into the harness that corresponds to the correct pins.
Heated steering wheel mod - success!-harness1-jpg  Heated steering wheel mod - success!-harness2-jpg  Heated steering wheel mod - success!-harness3-jpg  Heated steering wheel mod - success!-harness4-jpg
Old 01-08-2024, 02:43 PM #45
I was able to modify and add the harness. Happy to finally say that this mod has been done and is a success! In time for the first snowfall of the year here in Vancouver, Canada. Had it on for the 45min drive to work with no issues and no overheating. Just a nice constant heat for my hands that is not overly hot.
connectors , expert , plan , steering , wheel
2023 heated steering wheel and back up camera Blackwatch 5th gen T4Rs 22 01-27-2023 04:22 PM
‘23 TRD ORP HOURS OLD.But how about this nav? Also came with HEATED STEERING WHEEL MickeyR 5th gen T4Rs 9 10-11-2022 04:39 PM
Steering Wheel Shimmy, too much information kiana 3rd gen T4Rs 13 05-04-2018 01:19 PM
Heated Steering Wheel johnsonsteve 4th Gen T4Rs 6 02-01-2015 09:06 PM
Heated Steering Wheel Retro-fit Hongster General Discussions 2 12-06-2011 06:20 PM
