Old 11-07-2023, 12:58 PM #1
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Heated steering wheel mod - success!
EDIT: It has come up that the OEM NON-HEATED clockspring is not sufficient enough to handle a heating pad. I plan to tweak this mod and make changes to heir on the side of safety. Please see post #54 for link to the other forum which goes into more detail.
So I plan to add heat to my 2015 SR5P steering wheel. After reading this thread I am convinced that it can be done to our 4Runners.
DIY: Heated Steering Wheel | Toyota Nation Forum
I recently bought a used cheap steering wheel which matched what I currently have from Facebook marketplace. Bought it to examine, take apart, etc.
So this is the first thing I need help with;
The 2 connectors inside the steering wheel have empty slots. I plan to use them to run the wire(s) from/to the heat pads/switch. My question is, where do these connectors end up (through the clockspring) and on the other side of the steering wheel? And specifically, which wire(s) on the backside relate to the blank slots on the connectors? I am not an automotive electrical expert nor good at reading wiring diagrams but I am willing to tackle this mod if I can get some expert help. Any advice or leads on where to start looking would be greatly appreciated! Here are the 2 connectors in question which shows the empty slots I plan to use;
Heated steering wheel mod - success!-steering1-jpg  Heated steering wheel mod - success!-steering2-jpg  Heated steering wheel mod - success!-steering3-jpg  Heated steering wheel mod - success!-steering4-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 11-09-2023, 01:02 PM #2
I removed the leather upholstery in preparation for the heating pads. Here's what your steering wheel looks like without it's skin.
Old 11-09-2023, 01:12 PM #3
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
So the clockspring has 2 plugs/harnesses on the bottom of it where the wires come out of, the yellow one is ABS, and the other one is for the steering wheel controls, it's directly under the clockspring on the bottom. Curious to see how you accomplish this, very cool mod if you can pull it off
It's the black harness shown here
Old 11-09-2023, 02:41 PM #4
Thanks! I plan to explore it this weekend. Not looking forward to moving the airbag out of the way so I can get a multimeter to the pins on the connectors. But from what I've read it should be fairly easy and straightforward. I think the most important thing is to disconnect the battery for at least 15mins. I will report back with my findings.
Old 11-09-2023, 02:54 PM #5
Just ordered the heating pads from Amazon Canada. Cost me just under $20!
Here is what I ordered;
Amazon.ca
Old 11-09-2023, 02:57 PM #6
Real Name: Chris
Real Name: Chris
Yep, as someone who's had their steering wheel and airbag off a lot in the last month, the biggest thing is unhooking the battery and waiting so the airbag is decharged. Removing the steering wheel is very straight forward, however I recommend a steering wheel puller for the first time
Old 11-09-2023, 03:07 PM #7
I'll look into it!
Would it not be possible by hand? Or is a puller used to reduce damage?
Old 11-09-2023, 07:17 PM #8
Would you happen to have a pic of the connectors behind the airbag? I won't tackle this for a few days and was just wondering if male ends correspond to the blank slots on the connector. No worries if you don't. Thanks!
Old 11-10-2023, 11:36 AM #9
Real Name: Chris
Real Name: Chris
The airbag connectors are the black and orange wires shown coming out of the clockspring? The 2 plugs you showed plug into the clockspring in the ports to the right of there
Old 11-10-2023, 12:18 PM #10
Sorry the answer was right in front of me! Thanks for clarifying!
So based on your pic it looks like there are male terminal ends that would correspond to the empty slots in the connectors. (Correct me If I'm wrong!) This is a good thing! Now just have to figure out which wires that would be! I will try this Sunday or Monday.
Just thinking out loud, if I find the corresponding wire that is connected to the blank slots, would I be able to tap into that to provide power from say the fuse box to send power to the switch -> heating pads? Or would I have to cut that wire? Just worried that there is something on the other end that would be affected. Why would there be a wire that leads to a blank slot?
Old 11-10-2023, 12:32 PM #11
Real Name: Chris
Real Name: Chris
I haven't studied the harness that closely but I would assume the blank spots are empty pins/wires. I have an extra clockspring sitting on my workbench if you want me to send you any pics of the plug
Old 11-10-2023, 12:45 PM #12
No don't worry about it! The only thing to do next is to take it apart and start testing with a multimeter. Until then, not much to do. Thanks for the input so far though!
Old 11-12-2023, 07:24 PM #13
So today I had time to remove the airbag so I can test the pins/wires of the empty slots with a multimeter. The empty slot as pictured here where the red wire is inserted, corresponds to this pin on the bottom black connector under the clockspring (top row 2nd from the right). Good news is the black connector on the other side also has the empty slot!
Since I have an extra harness for the cruise control, I depinned and removed the wires as shown in the 3rd pic. I will use these to insert into the empy slots on both connectors. One will lead to the heating pad from inside th steering wheel and the other on the clockspring side will go to the fusebox.
Q: Which circuit should I use in the fusebox? Suggestions welcome!
Heated steering wheel mod - success!-pin1-jpg  Heated steering wheel mod - success!-pin2-jpg  Heated steering wheel mod - success!-pins3-jpg
Old 11-19-2023, 10:50 PM #14
Heating pad came in today! Did a test fit and realized that I need to do some trimming to prevent bunching of the material.
Heated steering wheel mod - success!-heatpad1-jpg
Old 11-19-2023, 10:53 PM #15
Here's what it looked like after trimming of some material.
Heated steering wheel mod - success!-heatpad2-jpg
connectors , expert , plan , steering , wheel
2023 heated steering wheel and back up camera Blackwatch 5th gen T4Rs 22 01-27-2023 04:22 PM
‘23 TRD ORP HOURS OLD.But how about this nav? Also came with HEATED STEERING WHEEL MickeyR 5th gen T4Rs 9 10-11-2022 04:39 PM
Steering Wheel Shimmy, too much information kiana 3rd gen T4Rs 13 05-04-2018 01:19 PM
Heated Steering Wheel johnsonsteve 4th Gen T4Rs 6 02-01-2015 09:06 PM
Heated Steering Wheel Retro-fit Hongster General Discussions 2 12-06-2011 06:20 PM
