Old 11-16-2023, 08:53 PM #1
Nodents2017 Nodents2017 is offline
Nodents2017 is on a distinguished road
What pressure for standard load 265/70/17 Ridge Grapplers?
Been struggling with steering wheel vibrations at highway speeds and figured I would try inflating my tires more so than usual to see if it would help. Inflated them to 38psi and the steering wheel shake is gone. Is that too high to run standard load tires? Before when I had them at 32psi the side walls looked like they were sagging. The tires say 44psi as the max so I figured 38psi would be ok to run.
Nodents2017 is offline   Reply With QuoteReply With Quote
Old 11-16-2023, 09:14 PM #2
J\d\C J\d\C is online now
J\d\C is on a distinguished road
Iíve run my standard load Wildpeaks at 35.
J\d\C is online now   Reply With QuoteReply With Quote
Old 11-17-2023, 09:06 AM #3
the tire rating psi is for the max load rating of the tire. it may or may not be the same as what toyota calls out for. if it fixed your shake, then leave it. chances are youre over the load rating of the toyota with those tires anyways so youre safe.
38psi , load , standard , steering , tires
Choosing 285's - LT load range C or Standard Load? Tire Recommendation T4Rrunning 5th gen T4Rs 4 03-11-2022 02:10 PM
TRD Pro, Cornfed 2/1.5, Ridge Grapplers 285/70/17 mstgkillr 5th gen T4Rs 5 05-01-2019 03:30 PM
New Ridge Grapplers Question Leatherneck 4th Gen T4Rs 8 05-09-2017 10:52 PM
