Old 11-20-2023, 02:43 PM #16
BorderCat BorderCat is offline
Real Name: TJ
BorderCat is on a distinguished road
Real Name: TJ
I have a 18' SR5 Premium and a 19' TRD OR Premium and as far as interior aesthetics there is very little difference (minus 4wd operations). Same heated seats, sunroof, lighting on side mirrors etc. But I will agree with other members that I would rather have options that I rarely use but know they are available when I need them.
BorderCat is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 05:25 PM #17
dandingo13 dandingo13 is offline
dandingo13 is on a distinguished road
Originally Posted by fotorunner View Post
Currently looking to replace my 2000 T4R with a Gen 5. Looking at these two. I know the ORPremium has some additional stuff, a locker for one. But I'm wondering if there is a difference in the suspension between the two?
Any other thoughts on this comparison would be appreciated.
I looked for a 4Runner for around 2 years and went back and forth on this a few times - SR5 Premium vs ORP. I really wanted an ORP but I'd get impatient and start considering the SR5P, convincing myself I'd never need a rear locker. Now, I don't plan on doing a ton of off roading.
I do have a friend, however, who doesn't do a ton either and has an SR5 and told me he's gotten stuck 2-3 times where a rear locker would've gotten out. This sort of solidified my decision, also considering that the ORP has multi terrain mode, better seats IMO and a few other things. I got a CPO and the price difference was right around $2k between an SR5P and and ORP.
This is the newest truck I've ever bought and I've worked my butt off building my business for the past 12 years so I wanted exactly what I wanted within reason. Heated seats, rear locker, etc. This vehicle is also my mobile workstation and do occasionally have to go on mild dirt roads. I was actually at a house on 10 acres last year after dark in the rain and my old '05 4Runner with 2WD almost got stuck. Happened at another job in the desert where I barely got out of the sand so I consider this somewhat of a necessity for me. We'll also be moving to a state that gets a lot of rain and a little snow
dandingo13 is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 05:34 PM #18
Burn* Burn* is offline
Burn* is on a distinguished road
I have the ORP w/KDSS and would definitely suggest to avoid the KDSS if you are an avid off-roader. It does make a nice difference driving on the road, but limits how you modify/lift in the future. That's something I'm dealing with now, trying to lift and moodify but it makes it much more complicated. I'd recommend the ORP if you need the locker w/o KDSS to make it more modifiable.
Burn* is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 08:36 PM #19
Old Tanker Old Tanker is online now
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
I have not found KDSS to be a limitation off road. Installation of a 2 inch lift was not a problem. KDSS loosens up at low speeds in 4Lo (and you can install a KDSS switch to manually free up the system at other times). I would agree it is a waste if you intend to rebuild the entire front end geometry - upper and lower control arms etc - for a long travel set up. But even there, Total Chaos has an option for KDSS rigs.
This having been said, if I were to do it again I would go with an SR5. You still have 4x4, you still have A-TRAK, and you can install a rear air locker when you change over the gears and install an air locker in the front.
So - if you intend to run a relatively stock set up - upper end of the build being new Upper Control Arms, upgraded suspension, body mount chop, high clearance bumper - and you don't mind being pushed to buy a sunroof package - an ORP, with or without KDSS, isn't a bad choice. If you think your future includes portal axles, or a long travel setup, or you really want an air locker in the rear to match the aftermarket locker in front - start with the SR5 and you'll have a couple grand extra to put towards the $15K - $30K investment.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is online now   Reply With QuoteReply With Quote
Old 11-20-2023, 08:41 PM #20
fotorunner fotorunner is offline
fotorunner is on a distinguished road
OP here,
Picked up an OR Premium today. No KDSS. It was very windy and cold and the heated seats are nice. That heated steering wheel switch is a bit awkward though.
I know T4R are classified as gutless but compared to my 2000 gen 3 it's got enough extra that I'll need to watch out or I'll add a ticket to the expense list.
It's white, Toyota must have bought white paint by the ship load because there's a lot of them around. But that will work for me, stays cooler in the summer. I'm sure I'll have additional questions in the future.
Thanks to everyone for your input, it made a difference in my decision.
fotorunner is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 09:12 PM #21
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
I like white. It’s a great color for planned neglect …
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 10:23 PM #22
gomiami's Avatar
gomiami gomiami is offline
Real Name: Jay
gomiami has a spectacular aura about gomiami has a spectacular aura about
gomiami's Avatar
Real Name: Jay
...and while I buy vehicles and drive them until they fall apart, the ORP would probably hold resale value a bit better than the SR5 because of those desirable off-road features.
2000 Honda Civic SI (EM1) Electron Blue Pearl - original owner, 238k and completely stock.
2023 Lexus GX460 Premium in Nightfall Mica. Picking up on January 2nd.
gomiami is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 08:04 AM #23
PhillySilver PhillySilver is offline
PhillySilver is on a distinguished road
Originally Posted by Pedro367 View Post
ORP is definitely the best bang for the buck. I wouldn't be unhappy in an SR5, but you definitely get what you pay for for only a couple grand more. Nicer wheels, hood scoop, locker, TRD badged softex, 4x4 shifter, etc. Better resale value too. I'd rather hardly use the locker than to not have it when I needed it.
+1 here with one personal caveat. The fake hood scoop never made much sense to me. My truck has it, I don't mind it per-se but why not make it a real one? My son has a 2023 Taco with kinda a double-hump thing going on with the hood which makes even less sense to me.
PhillySilver is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 11:46 AM #24
jhebert9 jhebert9 is offline
jhebert9 is on a distinguished road
I have a 2022 SR5,ORP. It does not have lockers or KDSS. My last 4 runner was a trail model. It had crawl control, lockers and KDSS. I loved the KDSS because of the improved ride and handling both on and off road. I did not have a lift so I don't know how hard a KDSS is to lift.
jhebert9 is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 11:48 AM #25
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about
thatoneguy's Avatar
OP here,
I felt the same way this spring when I went from my 1999 third gen to my 2023. Yes, the 4.0L V6 with the 5-speed is very dated, but compared to the 3.4L V6 with the 4-speed, it's got pep. It only really struggles if you're trying to go 75mph up a 6% grade, and I think that's mainly due to the gearing limitations. When 4th gear isn't enough, 3rd gear is a dramatic downshift at speed.
Enjoy your truck!
2023 TRD Offroad Premium, nautical blue
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 11-25-2023, 01:15 PM #26
Enjoy your truck!
My first 4Runner was a 95 Gen2. Now that was gutless. When driving in the mountains you had to use the downhills to pick up speed for the uphill. 3.4 was a huge upgrade compared to that. After driving the 4.0 a few days it definitely has more than the 3.4.
Old 11-25-2023, 04:18 PM #27
thatoneguy's Avatar
thatoneguy's Avatar
Word. Every memory I have of the Toyota 3.0L V6 is a bad one. They were just gutless wonders, hardly better than having the old school 2.4L 22RE (which I had in my old '87).
The 4.0L moves well, even in the 5th gen. Pretty sure 4th gens weighed less, and they had 1" smaller tires, so 4th gen V6's are probably a little quicker.
That said, technology has improved. The upcoming Tacoma's 2.4L turbo makes more torque at 1700RPM, like more that 100 lb-ft more, than the 4.0L does at the lofty max torque RPM of like 4400RPM. Anyone that is sick of slow is gonna get in the new powertrains, especially the hybrid, and never look back.
difference , locker , sr5 , suspension , wondering
FS: TRD Off Road Premium Fl Trunner11 For Sale: T4R Items 0 06-14-2023 11:29 PM
SR5 Premium or Off-road Premium? flynnstone 5th gen T4Rs 9 05-22-2022 03:29 PM
WTB: 5th Gen Off Road Premium or Trail Premium with KDSS PavementPrince$$ Want to Buy/Trade 0 05-22-2019 07:13 PM
