Old 11-20-2023, 01:35 PM #1
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
KYB Strut-Plus assemblies raise the front end; cheap Pro lift option?
Back in the summer, the wife decided check a text while driving and proceeded to run into 8" vertical concrete curb at 30mph and took out the entire passenger side front suspension and damaged both wheels and tires on that side of the truck. The repair shop used all OEM parts except for the shock and spring which I found a couple weeks ago was a KYB Strut-Plus preassembled strut/spring/top hat assembly.
About a month after getting the truck back, I noticed that the passenger side front sat ~3/4" higher than the driver's side front. I assumed it was just the new beefy spring needing settle and the fact that these trucks have a minor lean to the left/driver's side because the gas tank and transfer case sit to the left and perhaps it was always like this. The spring never settled after months.
A couple weeks ago while rotating the tires, I saw the KYB Strut-Plus SR4528 labeling on the passenger side shock. I checked the driver's side and it was still the OEM Tokico branded shock assembly. I looked at the shop repair order and it simply said "Shock/spring assembly aftermarket - $198". That's it. I've always been told you should replace suspension parts in pairs. Plus the fact that the passenger side sat higher never sat well with me. I ordered a driver's side KYB Strut-Plus SR4529 assembly from Rockauto for $123. I installed it a week ago and the driver's front is now within 1/8" (lower) than the passenger side. The rear wheel gaps are only fractionally higher than the fronts now vs nearly being almost 1" bigger with the OEM front shock/springs.
So, if you want to get an OEM "Pro" or Bilstein 5100 front end lift on the cheap and have no need for beefed up shocks/springs, this may be the cheapest and easiest way to go if your goal is to get that minor ~3/4" lift and basically equal wheel gaps at all four corners.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 02:32 PM #2
BorderCat BorderCat is offline
Real Name: TJ
BorderCat is on a distinguished road
Real Name: TJ
Where did you take your measurements from? Top of the inside fender?
BorderCat is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 02:44 PM #3
The interior upper edge of the fender to the middle of the center cap. The truck parked on a flat surface.
Old 11-20-2023, 02:52 PM #4
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
You should consider getting an alignment, if you haven't already.
02SE is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 03:00 PM #5
I figured I'd need to do it but the truck tracks perfectly straight, has much better, firmer on center feel, and isn't remotely as affected to road crowns prior to how it was prior to the fix. Makes me think the wonky ride height difference was influencing things. Prior to the fix, the steering felt loose and the truck on its tip-toes.
drivers , front , passenger , side , strut-plus
FS: 3rd Gen OEM Front Spring & KYB Shock Assemblies, Strut top spacers, $150 4Runner4Leon For Sale: T4R Items 0 09-26-2021 04:55 PM
Strut Assemblies ~ 2WD vs 4WD Chris311L 3rd gen T4Rs 3 12-14-2017 03:12 PM
Cheap Front lift Option 1da4 3rd gen T4Rs 6 03-23-2016 03:26 PM
Front Strut Removal During Lift **Method** bsdoig 3rd gen T4Rs 4 03-09-2015 12:54 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
