Old 11-18-2023, 12:53 PM #1
sactown sactown is offline
sactown is on a distinguished road
Do all aftermarket skid plates delete these parts?
I did some searches but wasn’t finding it so starting a new thread. I was putting in the Talon engine skid set and was a bit concerned that it requires the removal of these two brackets (pictured). They seem somewhat heavy and structural, is this typical of all aftermarket front skids or are there other brands designed to retain these brackets? I like the Talon catalytic converter skid cover which goes in easy, but this engine skid caused me to pause and investigate more. Any input is appreciated.
Do all aftermarket skid plates delete these parts?-img_4871-jpg
2017 TRD-OR w/ KDSS
sactown is offline   Reply With QuoteReply With Quote
Old 11-18-2023, 01:32 PM #2
AZ4Running's Avatar
AZ4Running AZ4Running is offline
Real Name: Neal
AZ4Running is on a distinguished road
AZ4Running's Avatar
Real Name: Neal
Some if not most heavy skids delete those. The skids are much stronger anyways so no worries there. Some skids keep the bars like the RSO/ARB skids.
2012 SR5P 4x4, 2018 TRD Pro front bumper conversion, Auxito LED head light bulbs, Ironman 4x4 Nitro lift with OME 888X front springs, RSO Suspension upper control arms, RSO Suspension prototype skid plates, DX4 Beast wheels, led ditch lights and brackets from Amazon, blacked out emblems, Victory roof rack, CTH ladder, more to come. Previous Rigs. 1997 SR5 4x4 no lockers, Trail Gear sliders, OME 881 890 lift and shocks, Magnaflow muffler, Airaid Jr intake, CBI ditch light brackets, Ebay led spot lights, 265/75R16 AT tires. 1996 Tacoma TRD Sport 4x4 2.7L MT bone stock on 32's.
AZ4Running is offline   Reply With QuoteReply With Quote
Old 11-18-2023, 02:09 PM #3
Thanks for your input. I searched for RSO skids but can’t find it, sorry don’t know that one.
2017 TRD-OR w/ KDSS
Old 11-18-2023, 03:52 PM #4
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Some do and some don’t. I have run both and it doesn’t bother me one way or another.
Old 11-18-2023, 05:25 PM #5
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
He may have meant RSG. Also, in some cases, there are skids for 4Runners equipped with KDSS that require spacers or purchasing a specific skid plate for KDSS. I had to remove a couple small braces by the cats to install my C4 transmission/transfer case skids.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 11-18-2023, 06:02 PM #6
AZ4Running's Avatar
Real Name: Neal
AZ4Running's Avatar
Real Name: Neal
I have their first prototype for testing, they will be available soon. They are just a copy of the ARB skid plates.
Old 11-18-2023, 09:00 PM #7
Is that these folks? Lift Kits & Tough Suspension Parts | RSO SUSPENSION
2017 TRD-OR w/ KDSS
Old 11-18-2023, 11:49 PM #8
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
It's a choice the manufacturers make when designing their skid plates. CBI made their plates to remove those braces, while others designed them to work with the braces. The manufacturers that remove the braces usually incorporate heavier bracing in that area to compensate for the removal.
The easiest way to tell if a skid plate works with the brace or not is to look for symmetrical mounting holes in the skid plate. If the holes are symmetrical, they use the factory braces, if the skid plate mounting holes are offset to one side, they mount with the factory braces removed.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 11-19-2023, 12:14 AM #9
mrblah's Avatar
mrblah's Avatar
also keep in mind, removing those braces don't necessarily give you more clearance either, its because the front diff is the lowest hanging fruit.
They may give you better approach angle, but not necessarily better clearance. It will depend on how the manufactures design the angle of the front plate.
Old 11-19-2023, 04:10 PM #10
Horsethief Horsethief is offline
Horsethief will become famous soon enough Horsethief will become famous soon enough
The RCI allows you to keep that stuff. I have all 3 RCI skids (,engine, trans, tcase) and didn't have to remove any components for the install.
The negative to the RCI front skid is that while Toyota claims 9.6" of ground clearance, I have a little under 8" of clearance under the skid with stock suspension and stock sized tires. I whack that skid quite a bit off-road.
Horsethief is offline   Reply With QuoteReply With Quote
Old 11-19-2023, 04:41 PM #11
AZ4Running's Avatar
Real Name: Neal
AZ4Running's Avatar
Real Name: Neal
Yes thats them. You can email them and ask when they will be releasing the skid plates. Raphael is who I have been working with. I tried to upload a picture but can't make it work anymore.
aftermarket , brackets , engine , skid , talon
Dealer Maintenance with Aftermarket Skid Plates pull4adv 5th gen T4Rs 16 03-24-2022 01:38 AM
WTB: Stock or Aftermarket Skid plates, 4th Gen Wile.E.Coyote For Sale: T4R Items 5 12-29-2014 03:14 PM
WTB: 4th gen aftermarket skid plates xxaarraa Want to Buy/Trade 0 11-10-2013 07:38 PM
WTB: 3rd gen fender flares and aftermarket skid plates terrytcl Want to Buy/Trade 0 07-10-2004 06:44 PM
