Old 11-20-2023, 06:03 PM #1
dandingo13 dandingo13 is offline
dandingo13 is on a distinguished road
Yet another mild lift post for a 2021 ORP
So I just picked up my '21 ORP and want a mild lift. Due to the fact that this is my daily, I drive this all over the place for my business and because I have a family, my ideal lift would be right around 1.75-2" in front (leveling) and another .75-1" in the rear.
I'm already pretty dead set on the Bilstein 6112/5160 or 5100 with Eibach 1" springs in the rear but everywhere I'm reading is showing that it's really around 1.5" in the rear since 4runners are light in the back. I know it's only a half inch but much of the reason of doing my lift is to remove much of the rake (still want a little). I'll also be running stock 265 ATs to retain as much MPG and comfort as possible.
I don't want to use spacers. I did that leveling kit with my '05 4Runner and the ride was harsh. When I got my '21, my wife even commented how much better it drives than my '05 so I want to retain as much of that comfort with some mild off road capabilities as well as having it sit a little better/higher than stock.
Has anyone used the Eibach 1" in the rear and had it stay at 1"? I've read you can use the '03-'09 Eibach 1" spring but I don't want to jerry rig it since It's a CPO under warranty and I'll be spending a decent amount on this lift. Any advice (and especially pics with your setup) is greatly appreciated.
dandingo13 is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 08:16 PM #2
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
The variable weight is in the back. Empty, it should ride higher.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 02:13 PM #3
BorderCat BorderCat is offline
Real Name: TJ
BorderCat is on a distinguished road
Real Name: TJ
I just got a 19' TRD OR and I'm going to go with the Bilstien kit as well after doing extensive research. I have heard nothing but good reviews without any real difficulties concerning the installation.
2018 SR5 Premium Barcelona Red with 60k.
2019 TRD OR Premium Super White with 17k.
BorderCat is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 05:40 PM #4
kenwilliams0803 kenwilliams0803 is online now
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
A .75" spacer in the rear only will do nothing to your ride and drive. Don't know what was up with your previous one.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is online now   Reply With QuoteReply With Quote
Old 11-21-2023, 05:52 PM #5
4skrunner 4skrunner is offline
4skrunner will become famous soon enough 4skrunner will become famous soon enough
I got exactly 1 out of my eibach rear springs.
4skrunner is offline   Reply With QuoteReply With Quote
Old 11-25-2023, 02:55 AM #6
Perfect, thanks. I'm almost positive that's what I'm going with.
Old 12-02-2023, 09:16 PM #7
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM is on a distinguished road
///AIRDAM's Avatar
Real Name: Adam
You can run a single 1.2" billet spacer up front and achieve a 2" lift up front without changing how it drives.
You can run the Eibach 1" rear spring and get 1.5" of lift on a 2wd and 7/8" lift on a 4wd
The rear of the 4wd sits higher, i would venture to bet the springs are different, but the 4wd is taller front and back versus a 2wd.
I have a 1.7" spacer up front and 1" eibach springs in the rear and my 4wd TRD sport is absolutely dead nuts level and rides barely different than stock. Maybe slightly firmer, but i suspect this is because i changed where the piston is inside the shock, since the pistons are further down in their stroke, they are likely in a position that reduces oil flow because shocks are made to reduce oil flow once they get to their topped out or bottomed out position, this helps slow the shaft speed down and keeps the shock from bottoming out. My setup gave me exactly 2.5" up front and 7/8" in the rear lift and my vehicle is absolutely dead nuts level.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
eibach , lift , mild , rear , stock
Which Mild Lift Setup Would You Do? Dwest 5th gen T4Rs 28 11-08-2019 09:51 AM
New TRD Pro - Need mild lift options CplTurner 5th gen T4Rs 83 09-05-2017 05:26 PM
Aftermarket UCA on Mild Lift? ZiaMan 4th Gen T4Rs 3 12-31-2016 10:09 AM
Mild lift kit? 01sr54x4 Off-Roading 4 08-31-2009 09:38 AM
Really Mild Lift hulk311 3rd gen T4Rs 9 03-22-2009 10:00 AM
