Old 11-20-2023, 08:27 PM #1
AC blend door actuator
symptoms: ac/heat doesnt change temp when the knob is turned. dealer diagnosed and said its the blend door actuator. they also stated code b1441.
who's done it, how big of a pain in the dock is the dash to remove to get to the blend door? I did a advanced search and nothing popped up.
dealer quoted 2500 to fix lmao
Old 11-20-2023, 09:32 PM #2
osugsxr osugsxr is offline
Seems tad steep, I changed one on a 2016 mks years ago. Part will probably be $50-100 tops. Quick search for repair there isnt much on the 5th gen but its probably near footwells or in the glove box area
**check out post #3 , 2nd diagram believe that is what you are looking for. Basically in the interior foot well area
5th Gen Limited HVAC Controls UPGRADE?
Old 11-20-2023, 09:36 PM #3
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
$2400 to replace a $100 part is always galling but doesn't sound absolutely insane to me given the labor involved. I just disassembled nearly my entire interior, dash included, and I didn't get as far in as you'd need to in order to replace that part. I wouldn't say the job is difficult but getting it in pieces without damaging anything (knicks and scratches) could be. My rig is already pretty beat up so wasn't a factor for me. Removal and reinstallation probably took me about 20 hours but I did a lot of cleaning and re-running aftermarket wiring while I was in there. YMMV
Few tips if you decide to do this yourself:
The upper part of the plastic housing around the harness behind the dash cluster is removable. Remove it after disconnecting the harness behind the cluster and save yourself a headache later on.
There's a bunch of airbags in there. Make sure your battery is disconnected.
If its not easy or relatively straightforward, you're probably doing it wrong - stop and re-evaluate.
Your steering wheel will be in the way. You'll have to deal with it or remove it. I chose to deal with it but bought myself a couple scratches on the dash (they have company). I have to imagine they install the dash before the wheel in the factory.
Skykomish is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 09:39 PM #4
Skykomish's Avatar
Skykomish's Avatar
If only. I couldn't find the exact diagram but here's the part OP is looking to replace (87106). It is fully buried:
AC blend door actuator-87b122c-gif
Pic from my rig with the area circled:
AC blend door actuator-pxl_20231029_221253448-jpg
Old 11-20-2023, 11:10 PM #5
thanks guys! yea that last pic is about what I expected. removing dash pieces/steering wheels isnt a big deal. the issue for me is that it's ALL the dash pieces lol. we have the perfect opportunity this week to knock this project out.
actuator , blend , dealer , door , pain
Blend door actuator stuck dphflytyer 3rd gen T4Rs 30 03-13-2024 07:48 PM
HVAC Blend Door Actuator P/N?? 4runn34 3rd gen T4Rs 1 11-01-2022 06:02 PM
Blend Door Actuator H1_VLTG 4th Gen T4Rs 22 01-07-2022 02:04 PM
Blend door actuator or ? DMX512 4th Gen T4Rs 0 09-29-2017 09:30 AM
Blend door actuator clicking tomrocksu New Members 0 09-22-2013 07:04 PM
