Old 11-25-2023, 07:49 PM #1
Cmiller1775 Cmiller1775 is offline
Real Name: Christopher Miller
Cmiller1775 is on a distinguished road
Front end noise help
I have had a front end noise happening for awhile mostly when hitting bumps and sudden shift changes from reverse to forward with hard braking. Went out to the dunes yesterday and the noise was so unbearable I finally decided to start troubleshooting issue. I have come to the conclusion that my inner tie rods are potentially bad but was wondering if anyone else could confirm or if im missing something. I have attached a video for your pleasure. I will appreciate all help given. Thank you ahead of time.
possible bad rack and pinion on 5th gen 4runner - YouTube
Cmiller1775 is offline   Reply With QuoteReply With Quote
Old 11-26-2023, 02:45 AM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I would jack up the front end and support the truck with jack stands on the frame. This unloads the front suspension. Then shake the wheels from top and bottom and side to side - looking for noise or excessive play. Also look at the steering componets and CV joints and CV joint boots.
Old 11-29-2023, 06:41 AM #3
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
I’d suggest you have someone else wiggle the wheel while you use your hand to check various components for the strongest vibration, as that should lead you to the source.
First guess is the steering rack, but hard to tell by the vid what else is moving.
That’s a pretty heavy rattle for sure.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 12-01-2023, 05:26 PM #4
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Looks like you have more than one thing worn out. Upper and lower ball joints and tie rods. Probably need to replace tie rods and both upper and lower LCAs, inclusive of ball joints. When it comes to front ends, I don’t piecemeal it. I generally replace everything as they are all interrelated and the effect of wear just compounds. Don’t procrastinate on this as it only gets worse.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 09:42 AM #5
I found the problem and I appreciate everyone's help. The inner tie rods were absolutely shot. I replaced them the other night and there is absolutely no more noise from front end and no more play in wheel. I had my neighbor come over and wiggle the steering wheel while I was under the checking components and the inner tie rods were moving like crazy. I had already changed out all the other ball joints and outer tie rods just never thought to change out inners. Lesson learned when changing out front end components always include inner tie rods. Thanks again for everyone's input.
ahead , confirm , end , front , noise
Front end noise FortCollinsT4R 4th Gen T4Rs 7 11-23-2020 09:40 AM
Front end noise Gus04Runner 4th Gen T4Rs 4 04-18-2017 06:19 PM
Need help with front end noise RikRunr Maintenance/Detailing 3 05-12-2012 09:37 PM
noise in my right front end shmoosername 4th Gen T4Rs 0 02-20-2010 06:33 PM
Front End Noise kwc280 3rd gen T4Rs 2 09-03-2008 06:15 PM
