Old 12-02-2023, 01:08 AM #1
Luke325i Luke325i is offline
Luke325i is on a distinguished road
May have made the wrong choice with a lift, can I get some advice?
Hi folks
2021 TRD Offroad with KDSS
I basically did a shit ton of research and weighed my usage scenario of the truck and pulled the trigger on this lift. I have KDSS so i wanted to keep the lift mild. I decided i wanted ~2.5" up front and 1.5-2" in the rear. I dont carry much extra weight, aluminum roof rack and rock sliders, under 100 lb probably.
So my research (which i may have screwed up) said to buy:
Bilstein 5100s all 4 corners
ARB(OME) 2885 up front
ARB(OME) 2895e in rear
Spacer to correct lean
JBA Upper control arms.
So i buy all this and get an email from TDOT Performance (was trying to buy in canada where i live) saying:
As per ARB USA, Part 2895 will not fit the TRD PRO. The correct option for the rear spring with a Spring Rate of 260 lbf / in is:
ARB USA 2889 - This is slightly cheaper so we can issue the refund
Old Man Emu 2889 Rear Coil Spring (medium Duty) | Free Shipping To Canada And Usa | Tdot Performance
IN STOCK
Please note that all Old Man Emu part numbers have now been superseded to the newer ARB USA part number branding.
Please let us know how you'd like to proceed.
Since the spring rate matched, and they claimed it was for a 2.0 rear lift, i said OK! sure do the exchange and sent it
Now im reading that those coils may infact cause a 3" rear lift and be waaay too stiff with no weight.
Did i screw up? Think Ill be ok with what they shipped?
Thanks in advance folks.
Luke325i is offline   Reply With QuoteReply With Quote
Old 12-02-2023, 12:15 PM #2
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
2885 front and 2889 rear will give you 3" of lift all around. the 2895e would have given 2" rear lift at same spring rate.
Also be aware that 2895e and 2895 are different heights too. 2895e=2", 2895=2.5" rear lift
With no weight in the rear, yes the 260lb springs can ride a little rough; more like "a truck".
2018 TRD ORP w/ Magnuson
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 12-02-2023, 12:44 PM #3
manofsteele2003's Avatar
manofsteele2003 manofsteele2003 is offline
manofsteele2003 will become famous soon enough
Why didn't you go with the OME struts/shocks?
2014 Sr5 Premium w/3rd Row, TRD Shift Knob
285/70/17 Falken Wildpeak M/T, TRD Skid Plate
SCS SR8 Brushed Copper Wheels, Huskyliner Mats
ICON Stage 2, JBA UCAs, KC Hilites Gravity Fog Lights
TRD Exhaust, Vision X Light Cannons
manofsteele2003 is offline   Reply With QuoteReply With Quote
Old 12-02-2023, 01:27 PM #4
yeah crap. Dont know why they said they wouldnt fit, i guess they arent an "official" coil for the 5th gen. Now the fun part, i need to see if they will let me return them and eat the shipping as its kind of their screwup.
Thanks for the reply, this is what i found out last night looking into it as well.
Old 12-02-2023, 01:30 PM #5
Yea that is weird as between all the 4runner models the rear spring fitment would all be the same. Only front springs on the PRO would be different due to larger shocks.
Old 12-02-2023, 01:32 PM #6
So if i only want 2.5 in the front then i should have gone with 2884s maybe? weird because some places say the 2885 is 2.5" in the front
Old 12-04-2023, 11:48 AM #7
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
You shouldn't need a spacer for the lean if you are not removing the KDSS, as the KDSS will automatically correct the lean ( so I've read).
The TRD Pro does not have KDSS and therefore will need a spacer to correct the lean.
2019 ORP KDSS MagGrey RSG Sliders 255/75/17 KM2 MT/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 11:59 AM #8
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
This is backwards. KDSS causes lean in lifted rigs and doesn't correct itself automatically. Not all lifted rigs with KDSS suffer from lean and some can correct it by re calibrating. Otherwise you can use the spacer or a coil designed to compensate for the lean. (Longer coil)
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 01:01 PM #9
Correct, I had 2883 and with NO extra weight I was at 2" exactly. 2884 would put you at 2.5, 2885 at 3" all with no weight. 2886 is for added weight.
Old 12-04-2023, 01:05 PM #10
why are they even mentioning the trd pro. he doesnt have a trd pro. and he bought 5100's so any lift from a trd pro setup is not a factor anyways. Find a new shop. and double check your part numbers lol. bilstein has a good rear spring btw. as does wheelers.
arb , buy , lift , rear , usa
Need advice on rear spring choice jdm-v35 5th gen T4Rs 8 12-20-2022 11:45 AM
Tire Choice Advice - 2018 SR5P jpaws 5th gen T4Rs 14 12-04-2018 04:58 PM
lift choice vinnysrunner 4th Gen T4Rs 1 10-02-2010 09:49 PM
Hope I made the right choice bowtoyclc 5th gen T4Rs 25 03-19-2010 03:52 PM
Advice: Things that can go wrong in Winter, and why... Thai Maintenance/Detailing 2 10-28-2004 01:15 AM
