Old 12-06-2023, 10:23 AM #1
Tazz 12 Tazz 12 is offline
Tazz 12 is on a distinguished road
Light flickering?
Just noticed one the license plate lights is flickering, I guess it’s a bad bub or is it a led?
Anyone know the part number?
It’s a 2023.
Tazz 12 is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 11:38 AM #2
BlueHenT4R's Avatar
BlueHenT4R BlueHenT4R is offline
BlueHenT4R will become famous soon enough
BlueHenT4R's Avatar
If it's a 2023 and you're near your dealer, stop by the service department. You shouldn't have a flickering light on a brand new truck that's under warranty. Let them figure out if it's just a bulb or something worse.
The license plate bulb is a 168 I believe.
2023 4Runner TRD Off Road Premium, Magnetic Gray Metallic
2021 Tacoma TRD Pro, Lunar Rock
2006 4Runner SR5 V6, Natural White
BlueHenT4R is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 01:57 PM #3
Something worse? Should I be worried, it’s not brand new bought it out of state but pretty much new.
Old 12-06-2023, 02:48 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Bulb info should be in the owners manual. You might want to check that the bulb is seated correctly. Also, you could swap bulbs to see if the problem moves to the other side. Don't swap any bulbs, or do any other work without disconnecting the battery first. Or, let the dealer handle it under warranty.
Old 12-07-2023, 08:55 PM #5
It's in the manual but it just says 5 watts type b so i wonder if it's led.
Old 12-11-2023, 12:14 AM #6
Jeff83 Jeff83 is offline
Jeff83 is on a distinguished road
Nope, they are just standard halogen bulbs. I just changed mine to LED.
Jeff83 is offline   Reply With QuoteReply With Quote
Old 12-11-2023, 02:53 PM #7
Humble Leader's Avatar
It’s a 2023.
if it's just one bulb then it's probably a bad bulb I think they are the standard wedge bulbs 5W you can get anywhere. 14v or 12v either work. the license plate lenses are fairly easy to remove you can swap the bulb and check. also while you are at it swap the crappy lense screws with stainless ones because I assure you the OEM screws will rust and you will have a bad day trying to remove them when your bulbs die
flickering , it’s , led , number , part
Oil light flickering, need help or suggestions Streetfighter 4th Gen T4Rs 26 01-18-2024 04:55 PM
Flickering light bar Samm25 4th Gen T4Rs 11 05-25-2018 03:46 PM
Flickering Battery Light TN4Runner07 3rd gen T4Rs 6 11-22-2017 03:38 PM
Battery light flickering. Dirtyfingers 3rd gen T4Rs 4 01-10-2014 07:57 PM
