Originally Posted by Tazz 12
Just noticed one the license plate lights is flickering, I guess it’s a bad bub or is it a led?
Anyone know the part number?
It’s a 2023.
if it's just one bulb then it's probably a bad bulb I think they are the standard wedge bulbs 5W you can get anywhere. 14v or 12v either work. the license plate lenses are fairly easy to remove you can swap the bulb and check. also while you are at it swap the crappy lense screws with stainless ones because I assure you the OEM screws will rust and you will have a bad day trying to remove them when your bulbs die
