Old 12-19-2023, 10:56 PM #16
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I guess the DIY fear is real?
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-20-2023, 02:35 PM #17
GNB GNB is offline
GNB is on a distinguished road
GNB GNB is offline
This is a very easy DIY job . Suggest a scanner to monitor transmission temp. The fill plug is unlikely to need replacing. Have gaskets for the bottom plugs.
I used a Motive Products pump to fill.
I used a torque wrench to tighten things up.
It seems like a more difficult job than it really is. But once you take a little time to understand the system , it is really a simple process ( albeit perhaps a little messy).
GNB is offline   Reply With QuoteReply With Quote
Old 12-20-2023, 09:49 PM #18
sr5owner?'s Avatar
sr5owner? sr5owner? is offline
sr5owner? is on a distinguished road
sr5owner?'s Avatar
Ordered the plug 90341-18059 from Toyotapartsdeal.com and it was correct.
Just for future reference if anyone has to order a new fill plug on their website the first pic they have is wrong!
The first pic is the check plug and the second pic is the transmission fill plug with WS on it.
I rolled the dice and they sent the right one.
If y'all want an affordable scanner that reads the transmission temperature, I bought the Ancel fx2000 for $140ish.
Hope this helps.
Transmission Fill Plug?-img_20231220_204338619-jpg
sr5owner? is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 06:04 PM #19
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Originally Posted by sr5owner? View Post
No. That's not it and neither is the one from the other thread. Those seems to be the check plug or drain plug.
The plug is very flat and it's body is hollow.
The oem plug has a WS on the head.
Thanks for the reply.
Hope this helps.
Where’s my apology?
Now, do the job and don’t be a monkey, use the correct tool, have patience, and you can put that replacement plug in your parts bin for the next 20 years or until you’ve sold the car or forgot about it.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 02:49 PM #20
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
LoL. The new version of the Toyota parts website sucks. It’s hard enough to find the part number then you’ve gotta deal with ridiculous descriptions or images. Googling sometimes makes it worse, like in this case.
The Lexus website is still the old version, it’s sometimes more helpful.
https://parts.lexus.com/p/Lexus_2010...034118059.html
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-05-2024, 05:28 PM #21
GNB GNB is offline
GNB GNB is offline
The transmission drain plug is soft metal.
Last week I removed it, and although it was torqued to exact specs, it was hard to turn. I got it out, but the 6 side socket rounded the plug surface.
When I saw that , I picked up a replacement plug. I have no interest in taking the risk for $4.
I have been doing all my vehicle maintenance since the 1980's and this is not common. The tranny drain plug as designed is 1) soft metal /aluminum and 2) the socket surface area is narrow.
As many have stated , ALWAYS remove the drain plug before you drain a drop fluid.
Old 05-02-2024, 03:26 PM #22
nastysoda nastysoda is offline
nastysoda is on a distinguished road
I've called two dealers in my area and both have given me the wrong info.
At $3-$4 a piece I think I'll just buy both. 🙄
Isn't it crazy, I rounded mine pretty good with a socket just like you, since it sits so flush. Called the dealer and asked 3 times, "it's the FILL BOLT, 24mm with a ws on it, not the drain or overflow, you have it right?" both dealers said yes yes this is it, even checked my VIN. When I show up they have the ****in hex overflow bolt sitting on the desk." I had the last dealer grab e mechnic and try to find it on their diagram.
I told him I need the new fill bolt, there are 3 bolts. he jsut gave me a stare with his mouth open, the flouride stare. Seriously feels like I'm in some twilight zone shit.
I've heard from some many parts guys, "it's a sealed transmission, lfielong fluid, we pump it in. But no one even knows the part number for the ****in fill bolt and gasket.
Hate people so much
nastysoda is offline   Reply With QuoteReply With Quote
case , fill , plug , ring , transmission
05 V6 transmission fill plug size Lugo Runner 4th Gen T4Rs 2 06-29-2022 07:47 PM
Transmission Fill Plug 4thGen4.7 4th Gen T4Rs 18 06-11-2022 05:30 PM
Can't get manual transmission fill plug off texadelphia 3rd gen T4Rs 19 01-26-2021 12:37 PM
transmission fill plug 95supra General Discussions 1 10-14-2017 12:08 AM
Help 2005 transmission fill plug? haroldpo6 4th Gen T4Rs 10 12-21-2010 12:43 PM
