Old 12-15-2023, 08:16 PM #1
fxoffroad's Avatar
fxoffroad fxoffroad is offline
fxoffroad is on a distinguished road
fxoffroad's Avatar
Shocks & Struts Advice
Need some advise...
I have a stock 2020 Limited w/ 55,000 miles. Should I replace the shocks/struts/mounts now? The vehicle feels fine... I'm getting what seems like more feedback over bumps/potholes than I used to.
If I do swamp them out, will the vehicle feel more solid over bumps and potholes?
'20 GX460 | SOLD: '10 Shoreline Blue Limited 4x4 | Terra Grapplers | 5" Stubby Antenna | A Well-worn Driver's Seat
fxoffroad is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 09:54 AM #2
Humble Leader's Avatar
if the shocks are fine why would you replace them - unless you don't like the ride. bilstein 5100s are said to feel similar to the XREAS which you have in your stock limited. what is your end goal with the vehicle? daily drive, pavement/some mild/moderate offroading, or build for offroad performance
Old 12-18-2023, 12:55 PM #3
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by fxoffroad View Post
Need some advise...
What are your tires inflated to? Over-inflation can cause what you described.
Also if the tires were replaced with a tire of stronger construction, that could be the cause.
02SE is offline   Reply With QuoteReply With Quote
Old 02-19-2024, 11:45 PM #4
fxoffroad's Avatar
fxoffroad's Avatar
I have Defender LTX M/S2 now, which replaced Dueler H/Ts. Inflation is probably at the recommended pressure- 38 or so.
Old 02-20-2024, 12:45 AM #5
That could be your problem. Toyota recommends 32 psi in the stock size, P-rated tires.
Old 02-20-2024, 08:00 AM #6
osugsxr osugsxr is offline
if its that bad you can probably be the first to retro fit the tacoma trd pro seat in a 4runner.
bumps/potholes , feedback , shocks , swamp , vehicle
99' Coils, New Shocks/Struts, but need advice on Daystar 1" leveling spacer install THEREALTOR1 3rd gen T4Rs 9 07-04-2011 08:37 AM
Struts/Shocks PowayDave Engines / Suspension / Wheels / Tires / Audio / Accessories 4 03-08-2011 01:53 AM
Need advice on getting new shocks struts biophase 3rd gen T4Rs 12 12-29-2010 12:37 PM
New shocks/struts advice Atreyus Engines / Suspension / Wheels / Tires / Audio / Accessories 9 10-29-2010 12:45 PM
