Old 12-20-2023, 01:25 AM #1
jonbert jonbert is offline
jonbert has a little shameless behaviour in the past
2011 Toyota 4Runner SR5 Airbag light remains on.
Fairly new at forums so pls forgive me if i screw something up.
I did a rare event and went 4 wheeling up a pretty easy mountain rd. A dead tree across the road was the only real jolt i got but not that bad. I went slow because didn't want a lot of mud to clean off in the cold. Stopped a few times to take pictures and picked up a rock for my home entrance (decoration). Is that legal in PA? Once off the trail i noticed the airbag light was on, not blinking. I did shove a couple rocks under the driver's seat earlier on the trail. then learned from google that a broken wire under the seat could cause this but didn't see, no, feel anything loose. I bought a cheapo OBD Code reader, but nothing obvious. Thought it would at least clear the light but no. Any ideas? Thank you. How will i know if anyone replies to this question?
jonbert is offline   Reply With QuoteReply With Quote
Old 12-20-2023, 01:14 PM #2
message's Avatar
message message is offline
message is on a distinguished road
message's Avatar
Unsure why the light would be on, but I assume it is due to a sensor malfunction.
If you haven't already taken it in, the 2011 falls under the Takata airbag recall so the Toyota dealer will replace it for free.
2011 Limited - TerrainContact H/T & Blizzak DM-V2 - aFe Pro DRY S - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
2004 SR5 V8 - BFG KO2 - Bilstein Shocks - FJ Springs - Air Lift Bags - Redarc Controller - K&N filter - AMSOIL Fluids - Woolwax Undercoat - Lasfit Lighting
message is offline   Reply With QuoteReply With Quote
Old 12-20-2023, 02:11 PM #3
Jeremy556's Avatar
Jeremy556's Avatar
He mentioned putting rocks under the driver's seat. There is wiring for the side airbag under the seat, which has likely been broken, and Toyota isn't going to fix it for free.
Going to need to remove the seat and inspect the damage. Just a few plastic covers at the ends of the seat rails, 4 bolts, a few wiring harnesses, and it comes right out. You will need a good scan tool (several hundred dollars) to talk to SRS module and get/clear its trouble codes. Usually SRS malfunctions will self clear in the event of an open circuit, once the wiring is repaired/replaced.
airbag , broken , light , seat , trail
Airbag Light & Seat Belt Light SirWilliamGoes 5th gen T4Rs 0 01-09-2022 02:31 PM
2011 4Runner Airbag Recall 4runnerNC 5th gen T4Rs 3 04-25-2017 11:01 PM
LED dash light A/C button remains green? SlickmisterN 3rd gen T4Rs 1 12-13-2014 10:52 PM
First Toyota anything (2011 4runner) shooter.mcgavin New Members 1 06-04-2012 09:23 PM
