Old 12-24-2023, 06:06 PM #1
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
Outer tie rod
Hello everyone, do you guys know if I should replace my outer tie rod. There is no play on movement just some grease exposed.
Thanks
Outer tie rod-img_2162-jpg  Outer tie rod-img_7554-jpg
Bonniem is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 08:21 PM #2
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
It's fine. A little grease leak is OK. The grease that seeped out was excess in the boot above the joint. My tie rods have seeped a little bit more grease than yours after 128K miles and I will not replace until wear is evident. My lower ball joint boots are showing wear, however the joint itself is still OK. It's a good idea to check front suspension components for wear once a year and more often if you off-road.
2023 ORP for wife, 2600 miles.
2011 Trail for me, 128k miles.
DougR is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 08:35 PM #3
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I bought new ones when mine looked like yours, but I’m waiting until they actually wear out before I install them.
List price is $61/ea now but you should be able to get them for $40 during a sale. I would go with OEM after hearing some complaints about Moog stuff. They come with the castle nut and cotter pin.
Steering Tie Rod End (Left, Right) | Part #4504669245 | Toyota Auto Parts
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 11:12 PM #4
Bonniem's Avatar
Bonniem's Avatar
That’s my LCA also exposed grease. Yes outer is easy to replace and money wise vs lower.
Outer tie rod-img_2163-jpg
Old 02-15-2024, 01:51 PM #5
RVCA2 RVCA2 is offline
RVCA2 is on a distinguished road
This
This is my outer tie rod and lca ball joints look like. 9 years of use. No off roading.
Outer tie rod-img_0974-jpg  Outer tie rod-img_0973-jpg
RVCA2 is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 11:32 PM #6
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Thanks
Exposed grease could be a sign of a failing boot, but it doesn't necessarily mean an immediate replacement of the outer tie rod. Give the boot a once-over for tears, cuts, or major wear. If it's just a small issue, you could clean up the joint, slap on some new grease, and throw on a new boot. But if the boot is seriously messed up or the joint is looking pretty worn, it's probably a good idea to go ahead and replace the whole outer tie rod.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 12:52 PM #7
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
For anyone looking to replace their outer tie rod ends, these Mevotech replacement ends work well and are recommended by a few local 4x4 shops.
Mevotech MES80895
Available in Canada from Parts Avatar and in the USA/Canada from Rock Auto.
Rock auto pricing beats parts avatar even with shipping and currency conversion to Canadian moose dollars.
I've currently got replacement LCAs and Outer tie rod ends enroute to me as it was the same cost for me to replace the entire LCA as it would have been to have a shop replace just the lower ball joint.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 02-18-2024, 01:19 PM #8
djeepin djeepin is offline
djeepin is on a distinguished road
wasn't any play in mine after 80K but seepage. I replaced just rubber boots on tie rod ends and ball joints. Japanese rubber deteriorate faster than metal wears out. change it proactive to avoid contamination of grease and wear joints. same is for front axels boots, and more expensive: steering rack. although latter more complicated and may require alignment tor toe. my point is: it start leaking or seeping grease - replace boot.
djeepin is offline   Reply With QuoteReply With Quote
exposed , grease , outer , rod , tie
OEM outer tie rods? atalarico 3rd gen T4Rs 8 10-04-2016 06:26 PM
Outer tie rod Myrunr2010 3rd gen T4Rs 28 10-04-2014 07:10 AM
Outer tie rod Whackmaster 3rd gen T4Rs 4 11-14-2011 10:57 PM
Outer Tie Rod Boot ViperFixer Maintenance/Detailing 6 04-08-2004 01:53 AM
