Old 01-12-2024, 07:04 PM #1
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
2014 left turn hyperflash sorry
Apologies to forum ,but haven't found a decent answer to this (w/o resistor) . Replaced son's low beams with led , had/have lasfit turn signals & shortly after install said leds ,started hyper ? So my olass took out all bulbs front & rear & still hyper . What am I doing or not doing right ? Could older lasfit leds be bad almost 2 yrs old . Thanks ! yes I searched so much now my eyes are watering
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-13-2024, 01:12 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
You took out the bulbs, didn't put anything back in? Of course they are going to hyper flash; that is how the car tells you have a burned out or missing light bulb.
Older LEDs from most any source will hyperflash because the load on the car isn't what it should be. Lasfit recently changed their design so they shouldn't hyperflash. You should never have to add resistors when you change to LEDs with modern light bulbs.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 01:28 PM #3
Ok thx @fkheath , knowledge what i need ! Assuming the left turn lasfit gone bad ,it comes on but doesn't indicate , Preciate the help
bulbs , hyper , lasfit , leds , turn
Turn Signal LED Hyperflash Solution knightsfs4 4th Gen T4Rs 15 06-04-2023 11:14 AM
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
Demello LED turn signal and hyperflash- Has anyone solved this issue with a resistor? PAULUNM 4th Gen T4Rs 7 11-05-2014 11:30 PM
Left turn rattle???? VT4runner79 4th Gen T4Rs 4 02-23-2010 06:34 PM
Pop noise on full turn left Flo4Run Problems & Warranty Issues 2 09-13-2006 09:24 PM
