Old 04-19-2022, 02:59 PM #1
futz_roy's Avatar
futz_roy futz_roy is offline
futz_roy is on a distinguished road
futz_roy's Avatar
Excess play front axle question
I was in the dealership for a rotate and balance for my 2018 TRD 4Runner. They came back and said that when the suspension is loaded with vehicle weight they noticed front axle had excess play. They suggested replacing front axle. I was pretty shocked to hear this for a vehicle so new. Is this total BS? Any insight is greatly appreciated.
futz_roy is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 03:20 PM #2
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
What do they mean by excess play? This sounds like a suspension issue than an axle issue. There should be no play in a CV a axle.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 03:22 PM #3
BillsRunner's Avatar
BillsRunner BillsRunner is offline
BillsRunner is on a distinguished road
Exceesive play or not
I've been having the dreaded needle bearing or front diff noise/vibration. Posted elsewhere on this site. I shook both axles just to see what's up (only 9K on her) and there was play. I asked the service manager at the dealership I trust if that was normal or could be causing vibration/noise. He responded that it was normal and many shops will cite it as a reason to replace. Any techs out there know for sure?
BillsRunner is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 04:15 PM #4
futz_roy's Avatar
futz_roy's Avatar
My plan was to check it out in my driveway when I get home, but would love to know more about what is “normal” vs excessive.
Old 04-19-2022, 05:42 PM #5
ive been told by experienced toyota guys the passenger cv has a touch of play, driver should be tight. YMMV. good luck.
Old 04-19-2022, 06:07 PM #6
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
Actually mines is the opposite, passenger had little to no play and the driver one flopped around. Talked to a Senior Toyota tech and he said this was normal, I went ahead and replaced the needle bearing with an ECGS bearing and most of the play went away. To the OP....if their going to replace it under warranty I would let them, see how much they would charge you to replace the bearing while they are in that area.
ProLee is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 06:31 PM #7
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Are you under warranty? If so… DO IT
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 06:32 PM #8
Sounds like the manager just doesn’t want any warranty work for his best friend turning wrenches.
Old 04-19-2022, 10:55 PM #9
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
The way the front diffs are one of the axles have a bit more "wiggle" than the other (I want to say the driver's side? it's been a while since I tested it). I remember I almost made a mistake and recommended a new axle and/or diff to someone until I verified it on another same year/model Tacoma.
We've been swapping out the factory needle bearings for bushings on our lift kits, haven't had any issues. I forget who we're using for the bushings though...
But if you're not experiencing any vibration, abnormal sounds, leaking axle seals, or anything out of the ordinary; I'd say it's probably perfectly fine.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 09:38 AM #10
futz_roy's Avatar
futz_roy's Avatar
They sent a video of the play in the axle.
When I was under the car, there was the same amount of play on the driver side and passenger side.
Any additional insight on if this is normal or excessive/unacceptable is greatly appreciated.
https://www.youtube.com/shorts/CRF0Z5UOBDk
Old 04-20-2022, 09:39 AM #11
futz_roy's Avatar
futz_roy's Avatar
Not experiencing any of the conditions that you noted, but will likely take it somewhere for a second opinion.
Old 04-20-2022, 01:59 PM #12
Vibration
I do have that vibration from 42 or so down to 35 or so. Goes away in 4WD so I do suspect the needle bearing. Going in next week and hoping for some relief. I believe the bearing most folks use is East Coast? Ours is under warranty for 10 years or 100K so I'm hoping not to have to go rogue but might have to. We'll see!
Old 04-20-2022, 02:54 PM #13
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
April 20, 2022 - YouTube
My CV axle moves like this. However, this video doesn't help much. The tech should have measured total movement with a dial indicator. Then we would have a number to compare with ours.
Get a specific diagnosis in writing. What is the spec for replacement? What symptom(s) do they observe? What does a dial indicator read? What parts do they recommend? Who pays? (I think there is no spec.)
DougR is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 04:19 AM #14
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
My driver side has a bunch of play, maybe 0.060”. From the forum I somehow concluded this is normal. No leak and no vibrations.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 09:31 AM #15
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
That lateral, side to side, play is no good. There should be a small amount of straight in and out play. I had the same thing happen on the driver side at 100,000 miles. Caused a vibration in the steering wheel under acceleration. I caught it way before it got as bad as yours is. I made a video the same way you did if you want to check it out to see the comparison. New axle time! You can refurbish them OEM gold bricks before they get really bad. I've been abusing the sh1t out of $60 A1 Cardones on the trail over a year smooth as a cloud so far. Kept OEMs for trail back ups. Here it's the vid link.
登录 Facebook | Facebook
Jakeepoo3 is offline   Reply With QuoteReply With Quote
axle , excess , front , play , vehicle
Cv axle play chris.andros.18 3rd gen T4Rs 6 01-13-2024 11:37 PM
CV axle play Ehahn84 3rd gen T4Rs 10 01-13-2024 11:24 PM
CV Axle Play keithyota 4th Gen T4Rs 1 11-25-2020 09:24 AM
CV axle clunks over bumps excessive play at front diff sickskinz 4th Gen T4Rs 1 01-26-2016 05:51 PM
Right front axle play at the differential Atomic_Dog Classic T4Rs 6 02-14-2012 04:10 PM
