Old 01-23-2024, 12:04 PM #1
slonny slonny is offline
slonny is on a distinguished road
Does the fuel pump prime on 5th gen with the key in the ON position?
Does the fuel pump on 5th gen turn on and prime for several seconds to build up the pressure, or it doesn't? I have read various opinions on older models of 4runners and Tacomas.
Looking at the electrical diagram, once the EFI relay and C/OPN relay are activated, it should get power even before the car is cranking.
I check mine yesterday and the pressure was 0 with the key in the ON position. I also put the ear next to the fuel tank when the key was in the ON position, and the pump was not running. It runs and build up pressure around 50psi when the engine is running, or cranking.
According to the repair manual (page 2469), you have to use Techstream to check the pressure with the key in the ON position.
slonny is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 01:30 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
The fuel pump does not prime when turning ignition to on. It will not run until you turn the key to the start position, the engine is running, or activated with a scan tool. It is quite audible from inside the cab when activated with a scan tool, with the engine not running.
Old 01-23-2024, 11:25 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Probably true for the 4Runner, but for some other Toyotas, such as my RAV4 hybrid, you can hear the fuel pump run for a few seconds when you open the driver's door to get it. Not sure why the difference.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-24-2024, 07:27 PM #4
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
I dont wanna give bad info, but, i recall my 2008 tacoma would ONLY turn the fuel pump on once the MAF detected airflow past it. So you had to be turning the engine over, for air to pass the MAF, before it would energize whatever relay that turns the fuel pump on.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
fuel , key , position , pressure , pump
Fuel Pump Relocation? or Fuel Pump Hatch? Cygnus 3rd gen T4Rs 3 01-24-2022 03:06 PM
Position of low fuel light pin on fuel tank connector eurasiaoverland 3rd gen T4Rs 8 10-15-2019 03:45 PM
Fuel Pump doesn't prime but starts 96pearlrunner Classic T4Rs 1 08-21-2015 10:18 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
quick! just installed engine and need to prime fuel hvguy 3rd gen T4Rs 4 03-22-2008 03:40 AM
