Old 01-23-2024, 07:17 PM #1
Busbd Busbd is offline
Busbd has a little shameless behaviour in the past
Brake pad size vs VW golf
Doing brakes on 5th gen and VW golf.
Really surprised to see the VW, which weighs 3000 pounds, has substantially larger and beefier brake pads compared to 4runner. As may be obvious, VW brakes are much stronger. Just sharing the observation.
Getting rotors off 4runner required many smacks with BFH.
VW is top pad in photo.
Brake pad size vs VW golf-img_0482-jpeg
Busbd is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 07:30 PM #2
manofsteele2003's Avatar
manofsteele2003 manofsteele2003 is offline
manofsteele2003 will become famous soon enough
Well that's the rear brake pad off the 4runner and probably the front off the VW, so I'm not really sure there's a comparison there
2014 Sr5 Premium w/3rd Row, TRD Shift Knob
285/70/17 Falken Wildpeak M/T, TRD Skid Plate
SCS SR8 Brushed Copper Wheels, Huskyliner Mats
ICON Stage 2, JBA UCAs, KC Hilites Gravity Fog Lights
TRD Exhaust, Vision X Light Cannons
manofsteele2003 is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 07:36 PM #3
CutthroatSlam CutthroatSlam is online now
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Also, looks like the VW uses a single piston caliper, whereas the 4R uses a 4 piston caliper in the front which affords far greater clamping force. I’ve got plenty of experience with vehicles that had weak brakes; the 4R is not one of them.
Looked it up and I was right:
Brake pad size vs VW golf-img_1882-jpeg
CutthroatSlam is online now   Reply With QuoteReply With Quote
Old 01-23-2024, 07:42 PM #4
Ah, I believe you are correct. Thanks!
Old 01-23-2024, 11:40 PM #5
use the threaded holes to thread a bolt in and itll push the rotor off without having to smack it.
Old 01-25-2024, 05:39 PM #6
Humble Leader's Avatar
agree. never had an issue with braking, but I also don't tow 4000+lbs. if you're towing heavy a trailer brake is almost required in any vehicle as a matter of safety and that's not a 4runner fault
Old 01-25-2024, 06:31 PM #7
This is correct. I occasionally tow a Clackacraft drift boat with the 4Runner, but most all of my towing is done with a K2500 Suburban diesel which I added a brake controller. Clackacraft trailer has no brakes as the boat weighs 450 lbs. Saltwater boats (Blackman 20 and Conch 27) have brakes. Conch 27 has electric over hydraulic brake actuator which I highly recommend. 4Runner doesn’t even sniff towing the saltwater boats.
Old 01-26-2024, 05:02 PM #8
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Your understanding of braking "power" is flawed. Frictional force is not dependent on Surface Area, just the coefficient of friction and normal force. Assuming the same pad and rotor material and temperature (CoF), the normal force (Brake Fluid Pressure x Piston Area) generated by the caliper is what gives you more or less friction force.
That friction force is then rotationally acting as a torque on the wheel. Using the same assumptions above and adding the assumptions ofthe same distance from pad to wheel center and same wheel inertia then again the braking power is down to the caliper.
If we add time and therefore heat into the equation, then the size of the pad starts to matter.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 02:46 PM #9
Per the above suggestion to use the threaded holes. Thanks for the suggestion. My limited does not have those threaded bolts, just unthreaded holes used to adjust the parking brakes. Wish I’d had the option to use the threaded holes.
Old 02-12-2024, 03:28 PM #10
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Did you look in the right place? The threaded holes are on the outside of the center dome part of the disk. They are relatively small, about 8mm. I have never seen a disk without them.
fkheath is offline   Reply With QuoteReply With Quote
4runner , brake , brakes , golf , pad
For those that game and enjoy golf GHARP57 Off Topic 1 09-09-2020 04:39 PM
Anyone down to do Anza Borrego and Golf Ram Hills? ahbot So Cal 12 12-17-2019 08:38 PM
FS Projectors from VW GOLF (EURO) ambush Classifieds - buy & sell (no commercial ads please) 0 10-27-2010 05:02 PM
Who else is addicted to golf? fitzt4r Off Topic 7 05-05-2006 01:40 AM
New Hobby - Golf Noloc Off Topic 9 07-22-2004 10:55 PM
