Old 01-24-2024, 07:58 PM #1
bamlin54 bamlin54 is offline
bamlin54 is on a distinguished road
oil level on dipstick
I have a 2023 4runner limited. When I got the car home after purchase i did my own inspection to see if fluid levels were good, wheel torque etc.. I noted that the oil level was about 1/3 inch above the max indicator on the dipstick. I checked the level several times in the first few thousand miles and it was always the same. Engine cold level surface. I just changed the oil for the first time along with filter, measured exactly 6.6 quarts of oil. After driving it for the first time and letting motor cool, checked level and it showed the same over fill level on the dipstick. Should I not worry about the level or add less oil during the next change to put the level on the dipstick in proper range?
bamlin54 is offline   Reply With QuoteReply With Quote
Old 01-24-2024, 08:17 PM #2
Whippersnapper02's Avatar
The dipstick is known to not be very reliable for a reading for the oil level. You can scuff up the end so it reads a little easier but typically the most complete line across if the correct reading. You do have some room in there for extra but it's not unlimited either.
Old 01-24-2024, 08:44 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Maybe I'm missing something here, but what is the recommended oil quantity for the V6? If you drained 6.6 qts. and reinstalled 6.6 qts, then I imagine the dipstick would read the same as before. If it calls for say, 5 qts. and you install 5 qts. you should obviously get a different reading on your dipstick. It may have been overfilled from the factory/dealer.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-24-2024, 11:20 PM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
No concern. A little over the line is OK.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 08:03 AM #5
I did not measure what came out, factory specs call for 6.6 quarts drain and fill with filter.
Old 01-25-2024, 09:55 AM #6
Humble Leader's Avatar
manual calls for 6.6 qt with the filter. if you did that then don't worry about it. I've noticed mine is slightly overfilled too when the dealer does an oil change. same with the wife's RX. never had any issues
Old 01-25-2024, 05:05 PM #7
Blackgoat Blackgoat is offline
Blackgoat is on a distinguished road
Who is checking Wheel Nut Torque?
Blackgoat is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 06:35 PM #8
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I do it by feel/experience with a tire iron cross wrench. I’m old AF and when you know, you know.
CutthroatSlam is offline   Reply With QuoteReply With Quote
checked , dipstick , level , oil , time
Hot dipstick level after transmission cooler install. FudgeYes 3rd gen T4Rs 1 07-09-2023 07:35 PM
Can you check the trans fluid level without the dipstick? jross20 3rd gen T4Rs 28 04-21-2020 04:15 PM
Quick sanity check on reading dipstick level V8 shahsmerdis 4th Gen T4Rs 7 09-01-2016 10:11 AM
Level the frame/running boards or level wheel wells Powder_Hound 4th Gen T4Rs 3 04-24-2016 12:31 AM
Motor oil dipstick level WTS Maintenance/Detailing 2 04-05-2007 10:49 PM
