Old 02-04-2024, 04:46 PM #1
Humble Leader's Avatar
hey baja designs - are my ditch lights supposed to fog up when I use them
so. I swapped my fogs for the baja sport fogs and installed a pair of s2 pro ditch lights almost 1.5 years ago.
I noticed that when I use the ditch lights a fog seems to appear on the lens on the inside when the air is cooler outside. I swapped out the gaskets, checked the lens for cracks but the same thing happened. I feel like this should not happen for such expensive lights in such a short period of time. they are supposed to be moisture sealed. anyone else having moisture issues when it's cold out? I suspect my fogs are also filled with moisture unless they are designed differently, but it's hard to tell with the amber wide cornering lenses on
I've had my OEM headlights and OEM fog lights for 12 years, and they have been perfect. I would expect better here for the price I paid. warranty or not, two lights should not have the same fate unless it was a bad batch... moisture should not be forming inside the light. boo
I get this is normal perhaps for lights that aren't sealed or waterproof but these have no vent port and are supposed to be IP67. to be clear the fog/moisture is on the inside of the lens, not the outside. see pic below of one of the pods. there's a section of the spot beam obstructed by moisture
update: spoke to Baja - they are taking ditch lights and fog lights back. will repair /resend under warranty
hey baja designs - are my ditch lights supposed to fog up when I use them-img_2472-copy-jpg
Old 02-04-2024, 06:04 PM #2
did you email them and see if they will help you out or just post on here hoping itd help? lol
Old 02-04-2024, 07:48 PM #3
They are actually quite active on forums. Iíve seen a lot of replies from Baja on the other 4Runner forum and the Tacoma forum.
Yes I plan to call them during business hours lol. I wanted to see if anyone else had the same experience.
Old 02-04-2024, 09:11 PM #4
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
all manufactures have a fail rate.
Hopefully, you get it sorted out.
Old 02-04-2024, 09:25 PM #5
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
If there's moisture in the lens, it might be because of condensation or water getting in there. Look for any signs of water sneaking in, even super tiny ones. Sometimes, those little gaps you wouldn't think much about can cause moisture buildup. Check out the seals and seams too. And don't forget to ensure the lights are installed correctly. Sometimes, if they're not put in properly, water can gather in spots and make things all foggy. Just double-check that they're set up the way the manufacturer suggests.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 02-04-2024, 09:45 PM #6
velogeek velogeek is offline
velogeek is on a distinguished road
Baja Designs lenses are user-serviceable so you can remove those 4 face screws and inspect the seal and lens. I had a moisture issue with an S1 light and found the seal was slightly pinched at the factory. They sent a replacement out and I was good to go.
When you reinstall, not a bad idea to wipe the seal down with some dielectric grease. Don't lay it on thick, you just need a little on your fingers and run the seal between them. It helps it seat in the channel a bit easier so you don't pinch it.
velogeek is offline   Reply With QuoteReply With Quote
Old 02-05-2024, 01:07 AM #7
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
Baja is quite responsive and great at their warranty repairs...... if you contact them.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 02-05-2024, 01:31 PM #8
nice
Old 02-05-2024, 06:34 PM #9
Baja Designs Baja Designs is offline
Baja Designs will become famous soon enough Baja Designs will become famous soon enough
Hey,
we have a lifetime warranty with our products and I can get you all taken care of. Please reach out to my email at brahianh@bajadesigns.com
Best,
Brahian Herrera | Forum Sales & Support
Email: brahianh@bajadesigns.com | Phone: (760) 560-2252 Ext 201
Baja Designs is offline   Reply With QuoteReply With Quote
Old 02-05-2024, 09:01 PM #10
NOICE.
Old 02-05-2024, 09:38 PM #11
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
NOICE.
Baja Designs actually replied before you posted this. Look up.
hoppyjr is offline   Reply With QuoteReply With Quote
Old 02-06-2024, 01:37 AM #12
mrblah's Avatar
mrblah's Avatar
im very impressed.
great excuse to buy some baja's
Old 02-06-2024, 09:43 AM #13
Originally Posted by Baja Designs View Post
Hey,
Best,
Thanks Brahian - I spoke to one of your colleagues yesterday, Anthony. he got me sorted out with the paperwork. appreciate the reply to the thread
It's nice to see vendors active on the forums and replying to threads. I still am puzzled how all 4 of my lights have a moisture problem, curious to know what the cause of it is. I thought maybe climate related and the deep freeze and thaw cycles where I live affecting the seals around the power cord. I guess I'll find out. the lights are fantastic though otherwise and put out way more light than I'd ever need, especially the fogs
Old 02-06-2024, 01:51 PM #14
Originally Posted by mrblah View Post
im very impressed.
I had some bolts seize in the housing of my s2s, sent them to baja, they replaced the housing, hardware, and brackets. Super great customer service.
2016 White TEP
Old 02-06-2024, 06:22 PM #15
hence my reply.
i'm a giant baja designs nerd btw. from retrofitting their stuff into headlights, to running them on my 66 vw bug.
fogs , inside , lens , lights , moisture
Baja Designs Ditch Lights w/Switch Pro 412Runner 5th gen T4Rs 5 02-11-2021 05:01 PM
Baja Designs Squadrons + Ditch Mount Sale! Battle Born Offroad Battle Born Offroad 1 04-27-2020 12:01 AM
Baja Designs Squadrons + Ditch Mount Sale! Battle Born Offroad Battle Born Offroad 9 05-10-2019 06:18 PM
