Old 02-15-2024, 02:06 PM #1
4'running'26's Avatar
4'running'26 4'running'26 is offline
4'running'26 is on a distinguished road
Idler Pulleys and Tensioner: Would You Replace All?
Hi, all.
I'm over 250k miles now and starting to get a little whine that I believe is coming from one of the idler pulleys. I figure before an 8000 mile road trip this summer I might as well replace all the pulleys. Would you replace the tensioner as well? Anything else I'm missing?
I already replaced the serpentine belt a couple years ago.
Thanks!
JT
--'00--Red--295k--Auto--SOLD
--'99--Green--204k--5spd--TOTALED
--'00--Black--165k--Auto--TRADED
--'14--Blue--250k--Trail Edition
4'running'26 is offline   Reply With QuoteReply With Quote
Old 02-15-2024, 02:33 PM #2
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
I would. I generally replace the belt, tensioner, and pulleys all at the same time and usually do it every 90k miles. If the belt lets go, it can often take other things out with it like expensive sensors or wedge itself behind the crank pulley and take out the front main seal.
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 01:57 PM #3
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
It’s not too hard to release the tension on the belt and check for bearing wear. You can buy the parts in preparation if you want but the tensioner is almost $300 list price, I’m personally not replacing unless it’s really needed. I bought the three idlers during one of Toyota’s 20% off sales but I didn’t have a spare $200-$300 laying around for a part that I might never need. Those idlers are still sitting in a box.
1000MPH is offline   Reply With QuoteReply With Quote
Old 02-16-2024, 11:14 PM #4
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Originally Posted by 4'running'26 View Post
Hi, all.
Thanks!
JT
Considering the miles and the whine, it's probably a good idea to swap out all the idler pulleys. And, if the tensioner hasn't been changed along with the serpentine belt in the past few years, it might be a good call to replace that too, just to be on the safe side for your road trip.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 02-19-2024, 09:00 AM #5
Thanks, all.
I'll start putting together a parts list and shop around.
Old 03-03-2024, 06:36 PM #6
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Since this thread is so recent I figure I'll just jump on it.....
Can you replace just the pulley on the tensioner instead of the whole unit? I've seen one of he pulleys listed as for the tensioner but not everywhere.
I'm just not clear if I need to order that as well.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 09:02 PM #7
1000MPH's Avatar
1000MPH's Avatar
As far as I know, you can replace the pulley on the tensioner assembly but you cannot purchase the (genuine Toyota) pulley separately. I have not replaced this myself. You could also replace only the (non-Toyota) bearings on these pulleys if you really want to and if you have a press.
Old 03-05-2024, 07:24 PM #8
AZ4ME AZ4ME is offline
AZ4ME is on a distinguished road
There is no direct OEM pulley replacement for the tensioner. You have to replace the whole unit if you want to stick with OEM. If you are good with aftermarket, you can use Gates 36325.
-Brian
AZ4ME is offline   Reply With QuoteReply With Quote
idler , pulleys , replace , tensioner , trip
Opinions on Gates idler pulleys JEL 4th Gen T4Rs 8 05-30-2018 10:39 PM
FS: 4th gen Weathertech liners & V6 water pump, pulleys, belt, tensioner Craigers For Sale: T4R Items 5 03-23-2016 02:21 AM
Timing Belt change- Tensioner and idler bearings? Hydraulic tensioner? DiskDoctr Maintenance/Detailing 10 09-13-2015 09:01 PM
Greased my idler pulleys T4RME 4th Gen T4Rs 0 06-01-2013 08:11 PM
Idler pulleys, bearings replacements. Black_TurboSR5 Classic T4Rs 0 09-18-2010 10:52 PM
