Old 02-29-2024, 09:55 PM #16
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by Bmnorm2 View Post
Rotational Inertia of a tire = m*r^2
Falken: I = (28.123kg * 0.4165m^2) = 4.88 kgm^2
Firestone : I = (24.358kg * 0.4305m^2) = 4.51 kgm^2
So, the Firestone will actually take less energy to turn. The Firestone results in ~ 7.5% inertia reduction. Due to the squared radius, often the larger tire will have a higher moment of inertia however in this case the mass is reduced enough for the taller tire to be a lower moment of inertia.
If both tires have the same rolling resistance, you may be slightly better fuel economy with the firestone. I have no idea what their rolling resistances are.
In general, I wouldn’t expect to see any notable difference.
The tread pattern definitely effects rolling resistance. As does casing construction, and rubber compound.
02SE is offline   Reply With QuoteReply With Quote
Old 03-01-2024, 11:06 AM #17
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Can tell you that my MT tires are the first set of tires I've had in which I've never had any punctures. The tread blocks are thick and never had anything ever puncture them..has been great. Every tire set have had before always got a puncture(usually debris from the shoulder is most likely culprit).
That being said, will most likely get some AT's for the next set....
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 03-01-2024, 11:47 AM #18
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
You have a close approximation but I = MR^2 only works for thin hoops which a tire is not really. The mass is distributed throughout the radius (serious calculus required). This approximation becomes worse when comparing MTs with heavier sidewalls to ATs and also different load / construction tires like we are doing here.
I think percentage difference between the two measurement is probably very close (7.5%) but the inertia you are calculating are higher than reality.
El Dusty is offline   Reply With QuoteReply With Quote
Old 03-01-2024, 03:59 PM #19
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
I’m aware. I intentionally made the broad assumptions required to seriously reduce the complexity of the problem. I agree very different tread patterns/depths can result in massive error from the assumptions made.
Also agree on your last paragraph. Was looking for a relative difference with same assumptions, not necessarily accuracy of the calculations.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 03-01-2024, 04:00 PM #20
Originally Posted by 02se View Post
the tread pattern definitely effects rolling resistance. As does casing construction, and rubber compound.
100%
lbs , lighter , load , tire , tires
Tire Decisions, Worth it to go Taller/Heavier? Unner 3rd gen T4Rs 61 05-25-2017 01:05 AM
'02 SR5 - Need Tire Recommendations - Want to go Larger cambone 3rd gen T4Rs 6 10-05-2010 10:20 PM
Smaller tire sized brands I should know bak3rme Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-25-2010 03:43 PM
Anyone go with a smaller tire size? velocty Engines / Suspension / Wheels / Tires / Audio / Accessories 7 09-12-2007 08:40 PM
Smaller Spare Tire? Koz 4th Gen T4Rs 13 06-22-2005 06:03 PM
